WANT TO DRAIN MY FUEL TANK.
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
ok you Gas tank camandos!
can i just undo the fuel lines to the fuel rail. and then run a hose to a fuel bottle and turn the Key on, it should pump right into the bottle..Right?
cars been sitting for 8 years with 10 gals of 110 unled race fuel
still smells fantastic..lol
every thing is is clicking and humming..sorta.. and nothing is coming out.
put the lines back on turn it off and on..take them apart. get a bit of fuel spary from pump up..but nothing flows out.. could my fuel pump be **** up? its still the first Pump from whan the car was new.. but it's only Got 30.000 miles on that Pump, and car... 92 z28
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: WANT TO DRAIN MY FUEL TANK.
i've done this before but you'll need to jumper the relay to keep the pump on.
that would be the ones on the fire wall just in front of the drivers side front window.. with the Bump gard..
ill unplug the relay..and use a jump wire on the power wire to Pump.
this should Keep it on.. and in turn pump out the fuel..right?
this is the first time it's been taken apart after Lingenfelters did the last install...lol
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
You should be able to apply 12 volts to the "G" terminal on the ALDL connector under the dash by your right knee, and then turn the key to "on", and it should pump the tank dry!!!
Car: '86 T/A
Engine: Vortec 406sbc-carbed
Transmission: 700r4-vette servo/B&M shift kit.
Axle/Gears: Ready to splode
I need to drain my tank too before the new engine goes in. But I'm carbed so no fancy electric pump tricks for me :/
A couple of ways for you to drain your tank is the old siphon way, or remove the tank!!
You could use an electric fuel pump, if you had one laying around........!!!!
If you chose the siphon way, get a self priming siphon at your local auto parts store ($3.00???), gas tastes crappy, and it's not really good for you!!!!
wana see 8 years of Dust?
remember this was street racing in the 90s
Broke in 02/03 and just sliped her into a box and locked it away.. till now..the Make Over
could it be that easy?.. take a single 12 Volt wire. and slip it over the G Terminal, on the ALDL, turn on the Key, and the fuel will flow into My track Bottles,(when set to with Line)
Yes, it should be that easy!!
I don't see any dust????
I hope that I don't see any glow in the sky either!!!
Be careful, sparks and gas fumes don't really go together real well!!
P.S. Looks like a real plumbers nightmare!!!
take that off and it's almost a stock fuel set up...almost..lol
Car: '86 T/A
For sure not dropping the tank. Too big of a headache. The gas has been in there for like 3 years with stabilizer in it but I'm not sure how much that helps after that long
3 years with stabilizer........no problem!!! I had gas in my car for 6 years with no fuel stabilizer, put in a new battery, turned the key, started right up, ran like a top, drove it to warm it up, and then passed a smog test with the 6 year old gas!!!
Smell the gas, if it smells okay...........!!!! I say run it!!! Once you start it, run it until it's good and hot, and then drive it, and fill her up with some super unleaded!!
P.S. Always store it with a full tank, oxygen has a way of oxidizing the gas, and then you have all types of problems!!!
Using the NOS.........kind of an unfair advantage...........oh well, every little bit helps!!
You have to maintain that original/sleeper look, gives you a bit more of an advantage, like a sneak attack!!
mine is 8 years old (Gas) and still smells fresh.. no sweet oily smell.
just going to Pump it out use it in my Truck.. and fill with the Good stuff
after all the New eng is 12.3 to1 and sitting at 427 Cid..
(JUST A STREET CAR)
(JUST A STREET CAR) Senior Member
It's easy for you to pump it out, but WS6LOVE's gas is a little bit trickier, he doesn't have an electric fuel pump, so, it's the siphon, or drop the tank!!
I say, burn it through the engine!!!
the bait with the 11/ on the window is Fun car ran Deep into the 10.s on the Bottles (old 383)
never mined the 9" under it..or the old school fuel pump and filter hangn out back..dont hide anything.. sleeper..NOT!..LOL
it would be hard to pull off the sleeper Car at this point, but it has been 8 years the last time it was on the street. ya never Know.
theres still 14" of room from the bottom of all that Junk hangn off the back..the photo just makes it look close, car sits stock hight, front & back, Im a Keep it stock Hight, type of Guy.
"Using the NOS.........kind of an unfair advantage"
Nothing in Street racing is UnFair!!
Car: '86 T/A
I was plannning to try the siphone, but it's not always easy to get the hose in there. If that did t work I was actually planning on running the gas. It shouldn't take me long to burn thru a few gallons with my setup lol.
As far as sleeper goes.... You lost the chance to have that effect as soon as you got an f body haha. I used to drive an '83 v6 firebird with a crappy 2bbl and no exhaust on it to school everyday. It idled low and was loud so everyone thought I had a 'huge v8'. No one would even try me. I thought it was hilarious
Burn the gas!!!!
I had a 1979 Malibu with the 120 HP 267 V-8, tin can for a muffler, sounded good, but didn't spin a wheel unless you were on dirt or very wet pavement!!
Talk about a sleeper!!
Passing up hill, not a good idea with traffic coming down hill!!!
THE SNEEK ATTACK SLEEPER LOOK? ..not so much for my Z28
A little less hood, and some window decals removed , and you'd be right there, the sleeper look!!!
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
