centerbolt valve cover question?
Old Apr 9, 2010 | 08:02 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
just a few gray areas
1) i had a problem with the rubber felpro gaskets staying in the valve cover theres no possible way i could expect to get the cover back on with that gasket staying put. now the gasket box says DO NOT use any rtv sealant.. anybody experience these problems??
2) i bought ultra seal gaskets from jegs. how should i go about keeping these put inside the cover.. all the equipment im working with is brand new besides the heads..
Old Apr 10, 2010 | 05:19 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: centerbolt valve cover question?
Get it in the best that you can.
Install the vc loosely.
As you start to tighten the vc down, work around the gasket surface pulling/pushing the gasket in place.
You may bleed a bit but you'll get it.
Old Apr 10, 2010 | 09:40 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i had the same problem when i put my aluminum valve covers on . cleaned covers surfaces , put several small dabs of RTV on covers , installed gaskets , held in place with many clothespins , took lunch break . put covers on ( minus clothespins ) , no leaks , worked for me . good luck .
MoJoe
Sep 24, 2015 09:12 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
