changed thermostat and slowed down car WHY!!!!!!!
Old Apr 10, 2010 | 09:16 PM
1b rock's Avatar
Transmission: a4
have a 90 iroc 350tpi car always ran close to being to warm with the factory thermostat....... car ran 8.90s and 9.00s consistant wether cool or hot......
i just put in a 160 thermostat and it ran 9.00 on first pass with engine cold,,,,, 9.36 warming up and 9.60 at operating temp........
no its not spinning and trannys not slipping as i rolled in the gas it feels like its not getttin all the fuel it does when cold
i let it cool down for an hour and ran the same times
Old Apr 11, 2010 | 12:47 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: changed thermostat and slowed down car WHY!!!!!!!
how are you running 8.9s with a tpi setup.
Old Apr 11, 2010 | 01:05 AM
TG Goose's Avatar
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
1/8th mile
Old Apr 11, 2010 | 01:11 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
well unless you have a custom chip for your car to run a 160 degree thermostat, then I suggest you try a 180 degree thermostat... most posts that I have read when it comes to thermostats have had poor results with 160 thermostats.... I think it has something to do with the ECM running in open loop... I had trouble with my Formula when I ran a 160, as well as when I ran a 190 degree thermostat... 180 degree thermostat was the sweet spot... I have a hypertech chip, which I believe called for a 180 thermostat... it's been so long I don't remember...
Old Apr 11, 2010 | 01:13 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
160 is too cold, step back up to a stock one.
Old Apr 11, 2010 | 12:15 PM
Artisan's Avatar
Car: 89 Iroc
Engine: 350/Dart heads/hotcam/TPI
Axle/Gears: 3.45 9bolt
+1 on the warmer thermostat. My Iroc has been on the rollers 3 times in the last 6 months. We know that currently it makes the best HP around 175. If you had a 170 that would work OK. A 180 would work well too. I'm not sure about the 190. My car does have a Custom (not off the shelf) chip in it. It is programed for a slightly cooler thermo than a 190. When the car is Cold say below 170 it just doesn't run as well.
Old Apr 11, 2010 | 08:12 PM
1b rock's Avatar
Transmission: a4
so im not crazy then i got to thinkin i did the same thing years ago with my 305tpi and it would run 9.50s cold and 10.s warm guess my theorys right then
180 i guess....... . waited till it cooled down and sprayed it the first time with a 100 shot and ran 8.30 at 86mph thanks fellas
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
