Need help with a ZZ4 cam up grade
Old Apr 14, 2010 | 06:20 PM
lkswarlock's Avatar
Car: 91 Camaro
Engine: 5.7 355
Transmission: T-5 Tranny
Axle/Gears: 373
Hi everyone well I'll make this simple I'm a newby and learning as I go, I've had this 91 camaro now for about 2yrs and and I'm bringing her back to life so the plus about this car is that it's a 355 TPI speed density set up, came with big mouth intake, big mouth runner, and had the plenum ported as well. The car has a lot of extras as well but I won't get into that right now, so my question is what do I need for this upgrade? I'm running the stock L98 heads I know I need springs because of the lift this cam has but can I just install the springs with out removing the heads? Or should I take the heads off and take them to a machine shop? I've read other threads on here about doing this upgrade but no enough info I know there a lot of you guys who have done this so any help would be appreciated thanks...
Last edited by lkswarlock; Apr 14, 2010 at 06:21 PM. Reason: wanted to change title
Old Apr 14, 2010 | 07:17 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Need help with a ZZ4 cam up grade
These GMPP ZZ4/LT4 springs are a drop in fit
http://paceperformance.com/index.asp...D&ProdID=24732
Springs can be changed on car; either use compressed air to hold the valves up or use rope inside the cylinder to do th e same
Old Apr 14, 2010 | 08:15 PM
lkswarlock's Avatar
Car: 91 Camaro
Engine: 5.7 355
Axle/Gears: 373
That's what I though too, but the guys at the machine shop told me to take the heads off that just replacing the springs isn't going to be enough. I think there just trying to make a buck off of me because of my lack of knowledge, I've done a little research and found out that the push rods also would be a good thing to replace, what do you all think?
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Magman
Sep 13, 2015 12:14 AM
Strick1
Sep 4, 2015 07:11 AM
