What the !#$% is this?
Old Apr 17, 2010 | 09:15 PM
hurd85ta's Avatar
Car: 85 trans am
Engine: 305 tpi
Transmission: 5 speed
Pulled my TB off today and found a caked on black residue. Has anyone ever expeirienced this before? If so what is this.
Attached Thumbnails What the !#$% is this?-008.jpg   What the !#$% is this?-018.jpg
Old Apr 17, 2010 | 09:37 PM
Stephen's Avatar
Car: 87 GTA
Re: What the !#$% is this?
Looks like carbon build up.
Old Apr 17, 2010 | 09:57 PM
hurd85ta's Avatar
Car: 85 trans am
Engine: 305 tpi
Its exhaust right. must be the timing?
Old Apr 17, 2010 | 10:02 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
poor maintenance IMO... ... gotta clean that throttle body every oil change or so ... at least every six months..
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
some of it is from the EGR valve.
most of it is from the PCV system.
its completely normal.
i've seen them sludged up much worse than yours'.
some good carb cleaner will clean it right up.
Old Apr 17, 2010 | 10:05 PM
stormdrop's Avatar
Car: 92 firebird or 91 wrangler
Engine: 3.1
that is the unpreventable black crud
GogglesPisano's Avatar
Use some Seafoam and Deepcreep on that. That stuff works wonders. Heres a link to the best how to I've found http://www.lt1engine.com/tech/how-to...arbon-buildup/
Old Apr 17, 2010 | 10:53 PM
MrMoustache's Avatar
Car: 1987 Firebird
Engine: 305 (LG4)
I just used Seafoam today to remove carbon build-up. It restored some lost power. Smoothed out the idle too. Great for my high mileage engine! (212,000 mi)
Old Apr 17, 2010 | 11:06 PM
hurd85ta's Avatar
Car: 85 trans am
Engine: 305 tpi
Looks like im going to the auto store tomorrow. thanks guys
Old Apr 18, 2010 | 02:58 PM
3rdgenred's Avatar
Car: 6.7 Powerstroke
do you suggest soaking the plenum inside carb cleaner?
Old Apr 18, 2010 | 03:13 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
NO DON'T DO THAT.... YOU need to use TB cleaner... Carb cleaner from my understanding has a different chemical structure compared to that of a throttle body cleaner...
Old Apr 18, 2010 | 03:18 PM
3rdgenred's Avatar
Ohh okay.
