looking to modify my 5.7...advice anyone??
Old Apr 25, 2010 | 09:28 PM
87TAGTA66's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: Stock 3.23's
hey guys i have a bone stock 87 GTA and looking to make some modifications in the very near future but dont really know where to start. im about to purchase a new 52mm throttle body since im told the stock one is very restrictive. anyone know who makes a good TB for a decent price? i also am getting a ram air box with kn filter with a ram air II hood. what should i do next?? i plan to put a mild cam in it but dont want to get too radical with it because itll still be my daily driver to work but also want it to be a pretty quick street rod at the same time. any help/advice would be greatly appreciated.
Old Apr 25, 2010 | 10:34 PM
87_TA_GTA's Avatar
Car: 87 T/A GTA
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Re: looking to modify my 5.7...advice anyone??
first off welcome to the site, and good choice with your car. once i get the cash, im doing everything on this list: https://www.thirdgen.org/forums/afte...-l98-mods.html
and for the manifold im gonna (hopefully) get the Holley Stealth Ram.
if you need any questions dont hesitate to ask anyone on here, and once again welcome to TGO
Old Apr 25, 2010 | 10:37 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
What kind of mods?
BBK makes a 52MM TB.
If you want to do simple mods, you can do under drive pullies, the TB, TB bypass, headers, exhaust, 1.6 roller rockers, larger runners, ported plenum, ported intake manifold, bigger injectors, adjustable fuel pressure regulator and an ECM tune.
Old Apr 25, 2010 | 11:15 PM
Blown84Bird's Avatar
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
one of them zz4 cam would work well , intake , headers, 3in cat back bigger TB will help. And stepping up to 1.6 rockers just make sure the push rod doesn't rub the inside of hole in the head. Or for a few bucks you could run Nos then its only fast with the bottle
Old Apr 25, 2010 | 11:22 PM
CamaroIROC88350's Avatar
I heard the Holley Stealth Ram Intake was non-emissions compatible? Someone mentioned to me that if you have one of those in your car & go to take a safety test for example and if the mechanic sees it he can fail you. Again, I'm not sure if it's true, but it's worth thinking about before replacing something as important & big as a intake manifold.
Old Apr 25, 2010 | 11:29 PM
I had performer rpm air gap on my car didn't have a problem. But Probably different in some states. And if that pimply kid faced doing the testing likes your car
Old Apr 25, 2010 | 11:38 PM
What kind of power did you get from that aftermarket part? I am in Missouri, here if you have one I think they might fail you. But again, I could be wrong.
Old Apr 25, 2010 | 11:52 PM
Old motor 280-300 I would have been impressed
But it was a good intake Carb stayed lot cooler then any stock intake
Now got a supercharged small block and wow big difference LOL
Old Apr 26, 2010 | 12:04 AM
You never took it for a dyno? I think the Holley Stealth gives an increase of 50HP & 50ft. of torque.
Old Apr 26, 2010 | 12:06 AM
You can get a Street & Performance Spacer & a Hypertech Air Charger. All in total it'll run about $160-$180 for both bolt-on's & it does increase power for sure. I know because I run with them on my ride.
I do want to warn you though, there are alot of liars out there & alot of knock off pieces of crap products so do your due diligence before purchasing anything. The 2 items I mentioned to you are legit & aren't crap. Good luck.
Old Apr 26, 2010 | 12:16 AM
.Dyno time cost money that I don't want to spend . Its always a good idea to stick with names you have heard of Holly, comp,headman,ect.
Old Apr 26, 2010 | 12:19 AM
It cost me $100 to do 3 runs last summer.
I agree, name brand is important. But sometimes there are brands that are new to the market that haven't been out long so those are worth looking into as well. The biggest names cost alot more money. TPIS also has an article that talks about alot of good parts to gain boost (HP) & torque. The book is for 3rd Gen. Camaro's/Firebird's.
Old Apr 26, 2010 | 12:47 AM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
save your money and pass on throttle body. get a free flowing exhaust, headers, cat and catback, and a tune up is always a good
Old Apr 26, 2010 | 12:56 AM
Old Apr 26, 2010 | 01:07 AM
Don't forget a cam, filters, upgrade your suspension & improve the chassis. It's not just performance that should matter, you should also improve on the strength of your car & it's nice to get some better gas mileage, even if it's a 1-2mpg gain. You can throw a whole mess of bolt on's on & the cam, CAI, headers, pulley kit, exhaust & get good gains. Our cars, the 350's which is in the GTA I believe, are capable of 400-420HP N/A.
What's the point of having alot of power if you're not going to be safe with it or not get some better gas mileage?
Old Apr 26, 2010 | 12:27 PM
danziger's Avatar
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
I would buy/build a cold-air induction instead of the "ram-air" hood/intake. Then I would uncork the exhaust with a set of headers, high-flo cat and cat-back. Lastly, I would get a tune...preferably on a dyno. JMO...YRMV.
Old Apr 26, 2010 | 12:33 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
You'll get nothing noticeable from just a throttle body alone, like others here have said start with the exhaust.
Old Apr 26, 2010 | 07:32 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
I did tpis big mouth slp runners 2460 headers cai air foil. And honestly my car goes well, but not like i expected. The intake is fully ported too.
Thinking about doing a cam. What cam would get me into the 300-325 rwhp range with stock heads, possibly with a little work done to them.
Sorry if im jacking this thread, but i think this will benefit the thread starter too.
Old Apr 27, 2010 | 09:57 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
The throttle body is not restricting your engine. Getting headers with a high flow cat and exhaust will also make a noticeable difference. After that I would look at a streetable cam and tuning.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
