engine misses, no troublecode
Old May 3, 2010 | 06:21 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
To good to be true. I have 7 month old Autozone spark plug wires, 1 year old spark plugs with the proper gap, Bosch III injectors, and new guts inside the dizzy; and my engine misses either in idle or driving. Get this, there is no trouble code. What could be the issue guys? Any advice helps.
Old May 3, 2010 | 07:27 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: engine misses, no troublecode
OBD1 systems are too primitive to set codes for misfire.
the only codes the old systems set are mainly for what are major problems.
my first guess, a bad AZ plug wire. i see them burned out regularly. usually they go bad at the spark plug, but sometimes they do it at the cap.
you can pull them off and use a DVOM to check resistance.
if you find one that seems bad, look inside the boot where the wire conductor comes out of the insulation, that is where they burn out most of the time.
Old May 3, 2010 | 07:30 PM
So I should check for the ohms or better yet, continuity right?
Old May 3, 2010 | 08:37 PM
Found it guys. Plug wire burned though. Rubbed up agianst the steering shaft and was arking there. Thanks guys.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Bryan F
Aug 18, 2015 02:28 PM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
