how to jump out or test EGR
Old May 9, 2010 | 05:59 PM
matt1970pon's Avatar
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
Axle/Gears: 3.45 g92
1987 Iroc z TPI 305. How do I jump out the egr or check to see if its working properly?I have a poor idle and stinky exhaust.I'm leaning at new injectors but also want to make sure EGR isn't bad.
Old May 9, 2010 | 06:16 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: how to jump out or test EGR
apply & hold vacuum to the EGR, check the diaphragm it should hold on the topside
this also should change your idle.
when the Vacuum is release the diaphragm should return
you can also check if it's leaking.. using MAP gas.. it will raise your idle.. if there is a leak
gta892000
Aug 11, 2019 11:16 AM
sahlomonic
Sep 20, 2015 07:15 PM
pacoelrapido
Sep 11, 2015 02:41 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
