TPI cam questions
Old May 5, 2010 | 08:21 PM
BAMNCO's Avatar
Car: 1987 Corvette
Engine: 383 Stroker
Transmission: 4 speed auto
Axle/Gears: stock
TPI cam questions
Hi, I have 1987 vette and I pulled the motor out and I'd like to get some more horsepower out of my l98 tpi with aluminum heads. So I thought a cam swap would be a good idea. Its a daily driver so don't want to fight it at a redlight and I don't know if you need to tune it after the swap? Post what cam swaps you did and how much you gain and change on the engine and give me your opinions on my situation. Also I'm getting headers from summitracing so I'd like to get the cam and lift kit there too. thanks
Old May 5, 2010 | 09:48 PM
fatam05's Avatar
Car: 89 formula ws6/1le
Engine: 305 tpi
Transmission: t5 with hurst
Axle/Gears: 3.43 posi
Re: TPI cam questions
the only cams that I know that you can put in without having to send the computer out for some different thinking is an lt1 or a zz4. Not sure of the lift or duration but I know that comp makes chevy cams (from what I have been told anyway) so I am sure you can find the same thing under a comp part number from summit. I just put an lt1 cam in my LB9 but have not fired it up yet so Icant tell you for sure what kinda numbers you will get but from what I have heard about ten to twenty ponies depending on which cam and what other adders you have. I would suggest putting some stock lt1 injectors in there while you have everything apart if you havent done so already of course, they just flow better.
Old May 6, 2010 | 12:15 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
If you want to buy a GOOD cam, do a search for the "1994 Z-28 LT1 Roller Cam." You can find them for as little as $40. There are very simiar to the L98 roller cams. Here are the specs to the LT1 cam
Dur:203intake & 208exhaust, Lift:.450intake & .460exhaust, Lobe Sepration:116. This is with 1.5 rocker arms.
Or you can buy a Comp Cams computer controlled cam for under $300 which is Computer Controlled (meaning that it is within the programmed parameters of the ECM).
http://www.summitracing.com/parts/CCA-08-500-8/
Old May 6, 2010 | 12:40 AM
BAMNCO's Avatar
Car: 1987 Corvette
Engine: 383 Stroker
Axle/Gears: stock
Does any one know how much a tune cost? Also I'm a noob at cam talk so can some explain how the Duration and lift numbers work. thanks
Old May 6, 2010 | 12:52 AM
BAMNCO's Avatar
Car: 1987 Corvette
Engine: 383 Stroker
Axle/Gears: stock
Also how much horsepower would I gain from a 1994 z28 am and how much from the cam for summit?
Old May 6, 2010 | 04:23 PM
Duration means how long the lobe keeps the valve open. Lift means the height of the lobe (How much it lifts the valve open). Lobe seperation means how far apart the lobes are from each other. The more it stays open, the better and air enters/leaves the engine. The higher the lift, the more air enters and exits. But you have to be within range of the ECM's programming. If you go too much, you'll run into vacuum issues and the Camaro will not run correctly. As for how much power, could be anywhere from 1-10 horses, dpending on everything else such as heads, intake, exaust system, and cars very own wieght and PROM settings.
Old May 9, 2010 | 01:21 PM
BAMNCO's Avatar
Car: 1987 Corvette
Engine: 383 Stroker
Axle/Gears: stock
How much horse power would I get for a zz4,zz9,lt4 hotcam. Also how much would I have to change for a stock motor and would I have to tune the car and how much does a tune run about ?
http://www.summitracing.com/parts/NAL-24502586/
http://cgi.ebay.com/ebaymotors/GM-Pe...ehicleQ5fParts
Old May 9, 2010 | 01:28 PM
I dont know. Let me ask a good friend of mine. He goes by the name of Chevy8588.
Old May 9, 2010 | 02:21 PM
BAMNCO's Avatar
Car: 1987 Corvette
Engine: 383 Stroker
Axle/Gears: stock
Old May 9, 2010 | 05:23 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
ZZ4 cam is the one the Chevy used with similar alum heads on the ZZ4 crate engine. Kicks a*** on TPI.
Muscle car idle sound . great idle and good performance.
471 INTAKE AND 510 EXHT WITH 208/221 DUR @ .50
Requires upgrade to ZZ4/LT4 springs ( should change out you old tired springs anyway )
http://paceperformance.com/index.asp...D&ProdID=24732
ZZ4 cams available as new crate engine takeouts under $150 ; sometimes less than $100
Will run with stock tune but tune can/should be "optimised" to get the best out of it; especially if you are doing other perf mods
http://www.pcmforless.com/index.php?...per&Itemid=316
Old May 9, 2010 | 06:35 PM
BAMNCO's Avatar
Car: 1987 Corvette
Engine: 383 Stroker
Axle/Gears: stock
How does the tune chip work and were can I get a zz4 cam. Links please thanks
Old May 9, 2010 | 06:51 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
zz4 cams are found all day long new on ebay, and used just about everywhere else. You'll never get a dialed in tune unless you or someone else spends some serious time collecting data and buring you a proper chip. Off the shelf chips will do little for you
gta90
Sep 15, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
Sanjay
Aug 12, 2015 03:41 PM
Fronzizzle
Aug 9, 2015 01:15 PM
