TPI conversion. Question about that sensor under the plenum.
Old May 19, 2010 | 08:02 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
OK well I am almost done with my TPI conversion i just have a question about that sensor under the plenum. What Exactly is it? I've heard many different explanations. I am using an 89 ECM And PROM. the Harness is an 88. Do I need this sensor because I dont see a plug for it from my harness. where would it be?
I appreciate any help. thank you
Old May 19, 2010 | 08:32 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: TPI conversion. Question about that sensor under the plenum.
IAT ;Inlet Air Temp sensor.
Some call it a MAT; Manifold Air Temp
Allows computer to adjust fueling based on inlet air temp changes
Has a short seperate harness that connects to a plug in the main harness back by dist ( same connectors ) which you are probably missing
Old May 19, 2010 | 08:52 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
thank you that helps alot. you solved that problem
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
