IAC sensor?
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: IAC sensor?
Passenger side of the TB, 4 wire square connector at the bottom and yes a bum injector will do that.
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Re: IAC sensor?
Just in case you havn't found it, there's a great 'sticky' type post on that subjuct that covers everything you'll ever need to know. I ended up copying it out and taped it inside my repair manual.
A thought about your gasoline smell. Does your engine have the dreaded 9th injector? I know the 350 TPI 87-88 did and they are famous for poluting the oil and causing all kinds of hinky crap till people delete 'em.
Nitro-Nicky
Nitro-Nicky
