The TBI to TPI conversion. I have a VSS question. Please help.
Old May 20, 2010 | 05:47 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
I am in the process of installing a TPI system in my 1990 Camaro. I am using an 89 "165" ECM and PROM. The harness is from an 88. On the new harness the plug for the VSS goes right down where it should. The only difference from my new harness and the one from my 90 Camaro with TBI is the pigtail is different. The wires are the same color. Can i just cut the pigtail and splice the old one on. Or do I need a new VSS. If so I need one for a 40 or larger tooth speedo gear. Can anyone help me out
Old May 20, 2010 | 07:58 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: The TBI to TPI conversion. I have a VSS question. Please help.
Someone will correct me but recall TBI cars had same 2000 pulse VSS as used on '89 and earlier TPI cars so you should be right.
'90+ TPI used 4000 pulse VSS
Old May 21, 2010 | 05:54 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
thank you. So I should be fine cutting the pigtail off my new 88 TPI harness and replacing it with the pigtail from my old 90 TBI harness?
Any other suggestions....?
Old May 21, 2010 | 10:24 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
If you don't have them already you will need a tpi throttle cable and a tpi kick down cable as the tbi ones are too short
Old May 25, 2010 | 09:23 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
I have the throttle and kickdown cable done and installed. Now since there is no difference between the 89 TPI VSS and the 90 TBI VSS then im gonna cut the pigtail from my 88 harness and splice on the one from my 90 TBI harness
Old May 27, 2010 | 07:32 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
thats what i should do right? I just dont want to mess this up
Old May 28, 2010 | 10:40 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You can't use an '88 harness on a '90 it will cause major problems with the firewall connections.
Old May 28, 2010 | 11:06 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
Harness is an 88 TPI And ECM system is an 89. The body is a 90. i have the harness in already and had it running my only problem would be with the vss
Old May 29, 2010 | 07:57 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
Is there any other problems with putting an 88 Harness and 89 TPI syste, in my 90 TBI car?
Old May 29, 2010 | 08:02 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
Have A VSS question, Someone please help me with this.
I have a 90 Camaro with TBI. I installed an 89 MAF TPI system with an 89' 165 ECM using an 88 MAF Harness on my car. I am confused on the VSS because I dont want to make a mistake and by the wrong one. I know the car uses the VSS for important reasons. I figure I should by a VSS for an 1989 TPI Camaro. I just dont know what it looks like. Could someone please help me out here
beachrodder
Aug 25, 2015 08:05 AM
Sanjay
Aug 12, 2015 03:41 PM
