305 tpi timing question
Old Jun 12, 2010 | 10:28 PM
jeinteriordesig's Avatar
Car: 86' I-ROC clone
Engine: 305 tuned port injection
I have an 86 I-ROC 305 tpi I took my timing chain off yesterday and switched to gear drive the set I bought has an aluminum timing cover with the timing mark on the left side, my factory timing mark is about 12 0'clock my old chain had a little slop so I want to check my timing I am using a hypertech performance chip and i had my timing set at 12 degrees advanced. I ran the car after the job was done and took it for a ride and it ran great but it seemed to have a little hp loss, how can I check the timing? thanks for any advise
Old Aug 19, 2010 | 07:27 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Re: 305 tpi timing question
i dont know if you know this but you shouldnt use gear drives on a computer controlled engine that uses a knock sensor... the computer is probably sensing some virbation from the gears and is thinking its knock and is pulling timing..
Old Aug 20, 2010 | 05:32 AM
I changed the car to tpi and the harness i used is out of an 85 and there is no knock sensor
Old Aug 20, 2010 | 09:27 AM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
ahhh ok then...
Old Aug 28, 2010 | 02:06 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Your timing should be at 6 degrees BTDC. Also, remember those hypertech chips have a ton of advance in them. You will probably run better at 6 degrees or so.
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
