TPI REBUILD
Old Aug 19, 2010 | 01:16 PM
schmitzdonald68's Avatar
Car: 1991 Z28 Convertible
Engine: 5.7 TPI
Axle/Gears: rear discs from 88 IROC/272 gears
TPI REBUILD
Hello all. I don't want to sound like an idiot, but I have very little experience with rebuilding motors. I did a 350 on a 79 z28 when I was in high school, but lets just say that was a LONG time ago and I am a little intimidated by the whole computer controlled car theme. I had a "trusted" mechanic build me a "new" 383 stroker roller motor about 2 years ago for my 86 Blazer and I don't think I got what I paid for ($6000 later).
I have one of the 3200 convertibles made that year and I want this to be my hobby car, eventually doing a full restore. The car itself is in really decent shape and for what I paid for it, I can afford to bring it back to original.
The reason I am rebuilding is due to the amount of oil leaking and the "black sand" I found when I looked under the valve cover. Oh, and the fact that when I start it cold, I have decent oil pressure but after it warms up, it is in the red.
I don't plan on rushing this rebuild. I plan on starting to disassemble the engine compartment next week and pull the motor the following week.
Is there anything that I should keep an eye open for throughout the tear down?
Thank you for your comments ahead of time.
Don
Old Aug 19, 2010 | 01:38 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: TPI REBUILD
Apart from that little bit of stuff that bolts on top, the L98 is the same as the 350 you did back then.
Old Aug 19, 2010 | 01:51 PM
Engine: 5.7 TPI
Re: TPI REBUILD
SUPER!! That makes things a bit easier. What about all the sensors? Should I replace them all since I am going through the trouble of rebuilding? Oh, and is there anywhere that I can get new aftermarket body/interior parts for my car? Ordered a Year One catalog, and I may as well be looking at a Summit Racing Catalog..very disappointing.
Old Aug 19, 2010 | 02:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: TPI REBUILD
If you've got a reason to suspect that a sensor is bad you can replace it, otherwise it doesn't matter much.
Old Aug 28, 2010 | 02:07 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: TPI REBUILD
Year one is expensive.
fbirdroller
Sep 2, 2015 10:27 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 10, 2015 08:42 AM
hokis
Aug 9, 2015 03:57 PM
