Engine problems
Old Jun 18, 2010 | 08:23 AM
musclecars90's Avatar
Car: 1986 Iroc Camaro
Engine: 305 5.0L
Transmission: 700 R4
Engine problems
I have an 86 Iroc with a 305 in it. On my way home tonight I got a service engine light that came on so I'm like no biggy I will pull the code wen I get home. Well I barly made it home, 10 min after it started to spudder every time I hit the gas. Finally I got it home and pulled the codes. Code 21 Throttle position sensor (TPS) - signal voltage is high and code 33 Mass air flow (MAF) sensor - signal voltage or frequency is high during engine idle.
Any ideas on the first thing I should do. Any help I would appreciate.
Old Jun 19, 2010 | 09:48 PM
powerslave's Avatar
Car: 87 Z28
Engine: TPI 350
Axle/Gears: 2:73
Re: Engine problems
I'd check the grounds to those, and the ecm.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
