No start after reinstalling dist/intake
Old Jun 20, 2010 | 03:20 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Like the title says. It did back fire out the intake so I thought it was possible the dist was backwards. So I had my wife crank the engine while i checked for compression on the #1 cylinder. When I felt compression I put the timing mark to 0 and checked the rotor. It was pointing at #1, 5 oclock position on the distributer. That should mean the distributer is not off correct? Or could it still be backwards?
Thanks!
Old Jun 20, 2010 | 09:19 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Re: No start after reinstalling dist/intake
So I tried to start it again tonight and again it backfired out the intake With the distributor installed as described in the previous post there is no way it can be 180 off right?
Any ideas on what else I should be looking at that would cause a no start issue or backfire out the intake when it does try and start? IAC have any effect on this?
Funny thing is before I pulled the intake the car pretty much insta started as soon as I cranked it and it had been sitting for almost a year.
Edit: If anyone can verify that the distributor is installed correctly with the info in the original post it would be greatly appreciated as I can start hunting for other causes. (if the dist was 180 off the rotor would be pointing approximately to 11 o'clock at tdc right?)
Old Jun 20, 2010 | 10:47 PM
cdornz28's Avatar
Sounds correct to me, What do you have timing set to right now?
Old Jun 20, 2010 | 10:59 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Well one problem is I cant get it started so I cant set the timing.
Old Jun 20, 2010 | 11:46 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
After messing with if for 12+ hours today and still no start
I'm going to pull the distributer tomorrow and rotate it 180 even though I am 99% sure it is in the right way now. Just don't know what else to try.
Old Jun 21, 2010 | 12:29 AM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
you need to set it top dead center FOR SURE turn it and feel compression, if the rotor is not on cylinder 1 i need to turn the oil pump so that the dist seats with the rotor pointing the right direction, to do that u need to modify a distributor shaft by grinding out the gears that way ull be able to turn the oil pump, also remember #1 spark wire should be pointing #1 cylinder as well
Old Jun 21, 2010 | 01:02 AM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
I decided not to wait till tomorrow and pulled the distributer and rotated the rotor 180. Reinstalled everything and....No start and backfire. Put the motor at TDC (balancer at zero with air blowing out #1) checked the rotor and it was pointing at #6.
So I had it in the right way the first time and am back where I started.
Really starting to think it could be the IAC.
Old Jun 21, 2010 | 01:13 AM
juanillox8's Avatar
Car: TOO MANY
thats why u really need the modified distributor shaft to turn the oil pump and set the rotor at #1
Old Jun 21, 2010 | 01:15 AM
juanillox8's Avatar
Car: TOO MANY
Didi u check you have the correct firing order on the cap?? or try rotating the dist cap and keep cranking it
Old Jun 21, 2010 | 05:32 AM
BADCAM70's Avatar
Car: 89 IrocZ
Engine: 5.7
Transmission: TH700
Axle/Gears: 2.77
With the no1 cylinder at tdc you should have the oil pump shaft pointing at number 5 intake valve so take of your valve covers and make it so,this you can fix with a long screwdriver.
Then insert the dist a little bit earlier so it rotates into the no 1 spot to land exactly at no 1 vire at the dist cover this should be easy,this will give you a very close hit to make the engine start.
regards Mats
Old Jun 21, 2010 | 01:32 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
The oil pump was in the proper position. I just used a long screw driver. If the oil pump was not in the right spot then the distributer wouldn't sit flush on the intake right?
Old Jun 21, 2010 | 02:01 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
that is correct, the oil pump shaft fits on to the roll pin in the dist shaft, otherwise it would not sit flush.
sounds like your dist is dead on, you need to make sure the ignition wires are not crossed.
Old Jun 21, 2010 | 08:50 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Changed the plugs and ignition module and it fired up for me finally. To bad the engine is toast When its warm and at idle it has zero oil pressure. The oil pressure goes up rpms though. Could be a bad sending unit I guess but it looks like its blowing blue smoke out the exhaust but it also smells very rich lol.
Old Jun 21, 2010 | 09:19 PM
juanillox8's Avatar
Car: TOO MANY
blue smoke is usually the piston rings... time to rebuild my friend lol
Orr89RocZ
Apr 25, 2016 08:28 AM
backtothe80s
Sep 5, 2015 12:39 AM
theshackle
Aug 23, 2015 03:49 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
