ok gurus, code 44
Old Jun 23, 2010 | 03:31 PM
turbinator3's Avatar
ok gurus, code 44
been fighting this code for a while blindly. found a shop today that has a scanner. we put the car on the scanner and it was running fine for a minute after cranking. the o2 was alternating like it should. all of a sudden, the o2 goes solid lean and the voltage starts dropping off. the car started missing at this point. we put a fuel pressure gauge on the car and it held solid 38 to 40 and increased with the rpm's. did a bleed off on the fuel rail with the car running and the pressure went to 3 or 4 lbs with not much fuel coming out of the bleed line. everything has been done to this car but a new pump. it has to be the pump. unhooked the o2 sensor and the car ran fine in limp mode. fuel pressure was still good, but volume was bad. any takers that's the problem?
Old Jun 25, 2010 | 09:28 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: ok gurus, code 44
Does this car have headers or the stock manifold? If it has headers, try swapping in a 3-wire O2 sensor.
Old Jun 25, 2010 | 10:02 AM
Old Jun 26, 2010 | 10:07 AM
no headers, stock configuration. we watched the o2 sensoer drop out on the screen. it was alternating back and forth as it should, then the car stated missing and it went solid lean on the screen.
Old Jun 26, 2010 | 10:23 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Might change the fuel filter first. If it improves for a while the pump may be bad. But with good pressure I'd think the pump is not the problem here. An O2 sensor is not a lot of money, might be time for a new one?
Old Jun 26, 2010 | 10:31 AM
new o2 probe last week. put the filter on it just before we hooked up the scanner. two things it could be. 1- the ecm is bad or2- it's the pump. pump had pressure, just not much volume
Old Jun 26, 2010 | 10:37 AM
o2 wire is good to the ecm. it sees it on the scanner. it takes about a minute or two for the car to start missing. it does it when it is bone cold too. will still be in open loop and do it. can't be the exhaust side. has to be a fueling issue. o2 sensor is not eeven in the picture in open loop
Old Jun 26, 2010 | 10:38 AM
cts read 198 degrees too.
Old Jun 26, 2010 | 10:43 AM
ricketts620's Avatar
Have you tried checking the sock on the fuel pump. That's what happened to my '92 a while back.
Old Jun 26, 2010 | 10:46 AM
we're gonna pull it after the fourth. might as well put in a new one while we have it out. i think it might be the original pump. it's on an 86 model.
Old Jun 26, 2010 | 11:57 AM
i had to splice some wires going to the mass air flow sensor. gonna go back over those again. gotta try all angles before i drop the tank. wiggled them aroung some and the car briefly idled better. worth another look.
Old Jun 26, 2010 | 11:58 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
If I remember correctly the MAF can be unplugged completely and the ECM will work around it and the car should run ok. Might be worth a try.
Old Jun 27, 2010 | 02:40 PM
yep tom, puts it back in limp mode.
Old Jul 17, 2010 | 08:33 PM
welp, turns out it was the maf after all. replaced it last night and baby relearned how to run right again! now to work on that dang code code 32!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
