tbi to tpi
Old Jun 23, 2010 | 11:11 PM
bigred75's Avatar
Car: 1992 25th anniversary RS Camaro
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
tbi to tpi
how diffucult would it be to swap from a tbi to tpi? would it gain any power? is it worth it?
Old Jun 23, 2010 | 11:37 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: tbi to tpi
If you could get a donor car would be muh better if not expect to spend about $800 in just parts. I was thinking of doing his swap too but then decided to just stay with tbi and drop a 350. But it's up to you to do the swap if you have the money I say go for it.
Old Jun 24, 2010 | 01:43 AM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: 700-R4
Re: tbi to tpi
Swapping out the current TBI for a TPI will definitely gain some power.
Old Jun 24, 2010 | 02:09 AM
bigred75's Avatar
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
Re: tbi to tpi
well there is a guy selling a full tpi unti down to the wireharness and computer for 300. about how much would i look at gaining?
Old Jun 24, 2010 | 02:53 AM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Re: tbi to tpi
Factory HP & torque informations:
TBI - HP: 170, torque: 255
TPI - HP: 205, torque: 285
Old Jun 24, 2010 | 06:43 AM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Re: tbi to tpi
I am pretty sure L03s and LB9's have more differences than just the breather setup but who knows. Your also gonna need more than just the tpi setup, There is countless threads on here asking about the swap. If I recall you will need a diff distributor and beefier fuel pump as well.
In the end, I say save the money and just purchase a L98.
Old Jun 24, 2010 | 08:13 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: tbi to tpi
You will see some increase, but you won't see factory tpi numbers, like others have said there are more differences than just the tpi.
Old Jun 24, 2010 | 01:51 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: tbi to tpi
It won't be the same since it's still gonna have the L03 cam and heads which is what don't help much on power although dyno don done his swap and I think he gained around 10 hp and 40 ft torque not sure can't remember, if you search you will find it.
Old Jun 24, 2010 | 03:19 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Re: tbi to tpi
The heads are different but some say that both the TBI and the low level TPI (205 hp) use the same cam. The distributor should be the same as I kept my OE dist. when I did my swap. There's a thread on here by someone concerning tuning and using the TBI heads with a TPI and the results which were impressive to say the least.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
