Two times to start
Old Jul 2, 2010 | 11:50 AM
dv013003's Avatar
Car: Firebird Formula 350
Engine: 5.7
Two times to start
Hey guys, my 350 TPI always takes two trys before she will start. This started happening a year or so ago. On the first try, it just keeps cranking. I let it sit for a minute, then try it a second time, and it sually catches. This only happens the first time I start it up that day. Any thoughts? Can this be caused by my retarding the igintion a couple degrees for nitrous?
Old Jul 2, 2010 | 11:58 AM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
Re: Two times to start
maybe its the timing, I would check the fuel pump relay, maybe its not priming and the ecu is waiting to see oil pressure to turn on the pump hence not starting the first time.
Old Jul 2, 2010 | 01:13 PM
dv013003's Avatar
Engine: 5.7
Where is the fuel pump relay located, and how do I check it?
Thanks again
Old Jul 3, 2010 | 04:33 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
the fuel pump relay is in the drivers side corner up on the firewall. When you turn the key to the on position you should hear the relay click and you can hear the pump turn on for about 2 seconds.
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
86Base
Aug 8, 2015 01:34 PM
