How do you set up an adjustable fuel pressure regulator ?
Old Jul 3, 2010 | 06:22 PM
timonator's Avatar
I just replaced my egr valve and while I was in there installed an adjustable fuel pressure regulator. All the instructions told me was to set it between 40-46 psi. I set it at 46 while the car was running and it now runs horrible. it dies after less then a mile. It's kind of hard to explain. It's like when I'm just trying to drive at cruising speed it hardly wants to move and surges all jerky. Then if I put my foot into it, it will go for a second and then fall on it's face, or just die.
Any ideas ?
Old Jul 7, 2010 | 12:17 PM
matt1970pon's Avatar
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
Axle/Gears: 3.45 g92
Re: How do you set up an adjustable fuel pressure regulator ?
try up or down in 2 pound incaments with fuel pressure. once you find the correct PSI back out 2 pounds.Then see how it runs.
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
