compressions check help
Old Jul 3, 2010 | 12:50 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
i have a tpi on an engine stand and need to check the compression to determine if i need to rebuild it but i dont know how to do that. my idea is to hook a battery up to the starter for a few seconds but there will be no oil running through it at that time so im hesitant to do that, will it damage the motor and if so how badly
Old Jul 3, 2010 | 07:35 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: compressions check help
Yea personally I wouldnt do it if it has no oil in it. Why not just fill it up with oil? Other than that as long as you generally know how to do a compression test sounds like you have the right idea.
Old Jul 3, 2010 | 09:32 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
the oil cooler lines are cut so it would just spill all over the place so i dont know what to do
Old Jul 3, 2010 | 09:59 PM
Well i don't know how they are cut off so i cant recommend anything specific but I'm sure you could work out some sort of a hose just to bypass the two ends together. I mean clearly it doesn't have to be anything nice for long term use but just something to get you through the test,
Old Jul 7, 2010 | 12:11 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
yea thats a good idea ill just connect them temporarily and hope oil doesnt go everywhere and what is the stock compression supposed to be
Old Jul 7, 2010 | 12:27 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
9.5:1 on a 86 firebird LG4
https://www.thirdgen.org/1986-pontiac-firebird
Old Jul 7, 2010 | 12:32 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
thanks but i have a 350 tpi i got out a z28 and on an off note, how would you find the year of an engine?
Old Jul 7, 2010 | 12:54 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Casting numbers, suffix codes, head cast numbers.
SUFFIX:
http://www.chevy-camaro.com/chevy-ca...s.asp?group=12
BLOCK CAST NUMBER:
http://www.nastyz28.com/sbchevy/sblock.php
Old Jul 7, 2010 | 01:37 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
ok well i cant find the specific year it just tells me 87 and up the block cast number is 14093638 which is 86-94, then my head cast number is 14101083 which is 87 and up, i want to find the exact year or does it not matter and there is no engine suffix code in front of the passenger side head
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
64goatman
Sep 9, 2015 01:09 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
TBRays98
Sep 6, 2015 05:05 PM
