86 Iroc hard starting, runs rough
Old Jul 30, 2010 | 08:01 AM
timonator's Avatar
Hi, I'm working on my daughters 86 Iroc again and it has a problem where it doesn't want to start. I noticed that it will start though when I hold the pedal about half open. It also runs really poorly and powerless when I drive it. I have replaced the fuel pump, pressure regulator, TPS, IAC, plugs,wires,fuel filter, air filters. I moved the intake air temp sensor to the air intake duct, that is the only mod that I have done.
Any help would be great.
Old Jul 30, 2010 | 08:19 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: 86 Iroc hard starting, runs rough
unplug the maf, see how it runs, if better replace the relays.
Old Jul 30, 2010 | 08:37 AM
timonator's Avatar
When I unplug the MAF it dies. I just pulled all these codes too:14,23,25,33,34,42,43,44
Old Jul 30, 2010 | 03:40 PM
unplug it first, then start the car
codes>>>
14 coolant temp sensor
23 intake air temp lo
25 intake air temp hi
33 maf hi
34 maf lo
42 est bypass
43 knock sensor or esc circuit
44 o2 sensor lean
some of these may be old codes
i think they are stored for 50 or 100 starts or something like that,
disconnect the battery to clear the codes
and see if any come back
Old Aug 1, 2010 | 07:58 AM
timonator's Avatar
I did disconnect the battery to clear the codes. the only one that came back right away was the code 43. Now I cant even to get it to run. In order to get it to start I have to pump the pedal repeatedly. I have to continue doing that to keep it running. As soon as I stop the car dies. I havn't been able to take a fuel pressure reading yet because my gauge is leaking for some reason.
All of the previously mentioned codes are fairly new because she has only been driving the car for 2 weeks.
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Sherpajames
Aug 7, 2015 06:56 PM
