zz 409 cam
Old Aug 1, 2010 | 02:03 PM
89lt1's Avatar
Car: 1989 firebird formula, 1991 z/28
Engine: none LSX! one day, 350tpi
Transmission: none t56 one day, t5
Axle/Gears: 9-bolt 3.45, 10 bolt 3.73
zz 409 cam
how well would a zz409 work with a superram and ported 083's
Old Aug 1, 2010 | 07:01 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: zz 409 cam
Not as well as it would with better heads. If you're going to spend money to work over the stock heads, you'd be well on your way to a set of AFR's or for a little less even a nice set of trickflows or something. Something to think about. What LSA are you thinking about. Is this going on a 350, 383...???
Here is an old thread that has a lot of good info/insight.
https://www.thirdgen.org/forums/tpi/...zz409-cam.html
Old Aug 1, 2010 | 08:12 PM
89lt1's Avatar
Re: zz 409 cam
well i think 112 deg. the whole thing isnt set in stone and i dont have a lot of money so probably 350 but if i could afford a crank and pistons by the time im ready to build maybe 383
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
