91 TPI Bolt Size Question, simple question, not so simple answer - HELP
Old Aug 4, 2010 | 03:38 PM
ws4v's Avatar
I'm assembling a 91 tuned port injection (off of a Z28) for an older vehicle. I have "almost" a complete bolt set with one bolt missing. It is the hold down bolt for the fuel lines at the front of the intake where a triangular piece of metal holds both the in and out fuel lines to the bottom of the intake. I have tried every size bolt that I can get my hands on with no luck. Threads appear to be metric but an 8mm bolt is a loose fit in the hole although the threads appear correct. I have even tried an assortment of SAE threaded bolts with no luck. Does anyone know what the bolt size is for this hole. I appreciate any help you guys can give me.
Ken
Old Aug 4, 2010 | 06:12 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 91 TPI Bolt Size Question, simple question, not so simple answer - HELP
On my '87 and '90 TPI intakes they are same size /thread bolt as holds runners to plenum
Old Aug 4, 2010 | 06:27 PM
Guest
Guest
Posts: n/a
AFAIK all the bolts that go into the intake manifold itself are metric. So... if its an 8MM bolt its just a different thread pitch than what you have. There are at least two and maybe three thread pitches for that size bolt. I'll see if I can find out which, I have an intake handy.
Well I cant find a 10mm bolt, but thats what it has to be. A 3/8" coarse almost threads into it so... 10mm should be correct. Its not 8mm, that slides right in with no real thread contact. So it should be a 10mmx1.5
Old Aug 5, 2010 | 08:31 AM
ws4v's Avatar
Finally found a parts drawing and list on the forum (didn't copy URL) but it is a 3/8" - 18 X 3/4" bolt. I ended up buying a socket head cap screw and cutting it down to about 1/2" in length to make it fit between the fuel lines and the plate. Thanks for everyones help.
Old Aug 5, 2010 | 08:42 AM
ws4v's Avatar
Looked back in my history and found the URL.
https://www.thirdgen.org/forums/tpi/...tance-tpi.html
There are three post with image files that show drawing and associated parts. I looked through the local dealers books yesterday but none show the detail that is in these drawings.
Thanks again,
Ken
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
wruiz
Aug 13, 2015 09:07 PM
Sanjay
Aug 12, 2015 03:41 PM
knight72
Aug 10, 2015 09:32 PM
camaroken83
Aug 10, 2015 11:35 AM
