Strange Problem
Old Aug 13, 2010 | 09:01 AM
bowlinstew's Avatar
Strange Problem
I have a 91 5.0 tpi z28, most of the time when i hit the gas pedal then take foot of it right away the rpms go down to under 500 the oil gauge raises up past 60psi the volt meter drops, sometimes the car dies, and sometimes it will idle back up and be fine, also when driving down road the car feels like it bucks (or misses cant tell) i can feel it the most around 40mph and above. Have new plugs, wires, cap, rotor, fuel filter, injectors are all at 17 ohms, my next thing was to check my timing. This problem is stumping me i not sure what else to do to fix problem.
Old Aug 16, 2010 | 10:38 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Strange Problem
Well for starters obvious stuff first any check engine codes? Also I'm going to assume this car is stock or does it have any modifications?
Old Aug 16, 2010 | 11:27 PM
bowlinstew's Avatar
Re: Strange Problem
no engine codes, as far as I know it is stock I bought it a month ago. The guy I bought it from only drove it a couple times after he bought it so he didn't know if the person before him did anytng to it. I checked the timing t was set at 8 degrees and I put it back to 6 seems to run better at 8, I noticed the bucking more around 20mph on 6 degrees and less at 45mph(but still there), more at 45mph then 20mph at 8 degrees
Old Aug 17, 2010 | 10:01 PM
affliction1's Avatar
Car: 89 chevy camaro rs
Re: Strange Problem
may need tune up,or spray carb cleaner aroung intake system sounds like vacum leak,and if its dieing its a pretty big one
Old Aug 20, 2010 | 01:16 PM
bowlinstew's Avatar
Re: Strange Problem
Fixed the problem not sure, what it was, but when i replaced the TPS and the connector, also put the timing at 0 degrees it doesn't buck anymore and the rpms don't drop down anymore
Old Aug 28, 2010 | 02:04 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Strange Problem
Start simple. Doubtful, but possibly a clogged fuel filter? Your timing should be at 6 degrees BTDC.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
andy74
Sep 3, 2015 08:41 AM
IROCtometal
Sep 2, 2015 02:01 PM
