Help with Cam choice
Old Aug 16, 2010 | 07:30 PM
red/white04's Avatar
Car: 88 IROC
Engine: 305TPI
I'm running a internally stock 305tpi/auto. I have a good exhaust and headers on it. Its been chipped. Stock converter with 3.73 gears. The car runs great, but I've been considering taking that peanut cam out and putting alittle more to it. I wish to retain the stock converter. What are my options? I've looked at quite a few different cams and I'm not really sure how far I can go. Yes its just a 305, I don't expect mind blowing power nor do I want it. I'm not swaping to a 350, this motor only has around 10k on it. Modified stock LT1 cam? LT4 Hotcam?
Old Aug 16, 2010 | 07:45 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
Re: Help with Cam choice
since your wanting to stay with the stock convertor id say the stock lt1 cam would be a good cheap option... lt4 hotcam is way to much for a 305 with a stock convertor the heads wont like anyhting past roughly a .470 lift you'll run into clearence issues with the valve guide after that. What ever you decide to do you will have to have a custom tune or it'll be a waste of time and money
Old Aug 16, 2010 | 08:48 PM
Car: 88 IROC
Engine: 305TPI
ok... so how far out of wack would it be if i did use the LT1 stock cam(what are the specs of that cam) could I atleast install it and drive... I would plan on doing a custom tune, but I don't always have access to a trailer.
Old Aug 28, 2010 | 02:14 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Do not exceed 220/220 duration @50. Do not exceed 470 lift either. You could always opt for a compu cam. Computer friendly ROLLER.
Old Aug 28, 2010 | 02:16 PM
ninetyone's Avatar
Axle/Gears: 3:42
Check out this cam http://www.summitracing.com/parts/HRS-180225/ Probably the best price on a roller out there and it will work with your stock computer.
Old Aug 28, 2010 | 08:23 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
An AFPR would be a good investment, also.
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Jorlain
Oct 8, 2015 01:57 AM
fbodyfreakls1
Oct 6, 2015 06:34 PM
ericjon262
Sep 11, 2015 06:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
