Typical/unknown tpi problem(s)
Old Aug 17, 2010 | 05:13 PM
Twinturbo502BB's Avatar
Ok, purchased a 91 z28 5.0 TPI auto camaro, runs fine but after about 30 mins, car bogs down, stalls and won't run for about 3hours.
getting no error codes.
whats been replaced:
new ECM
used but known working injectors
new map sensor
new temp sensors
new ignition module, rotor cap/button.
fairly new fuel pump
No vacuum leaks
has no cats on it
I drive it to/from work, anything after 30 minutes and the car will jump/and then stall out, will start for and idle for a few minutes then once drive is engaged and gas pedal applied=instant stall.
Anything to check for, advice would be greatly appreciated.
thanks
james G
Old Aug 18, 2010 | 02:08 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Typical/unknown tpi problem(s)
Ohm the injectors. They can get lousy as they heat up.
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
jbd1969
Aug 17, 2015 07:06 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
