91 z28 injection
Old Aug 29, 2010 | 09:24 AM
protestthehero's Avatar
91 z28 injection
So im having a problem
my 91 305 isnt running right, so i replaced a bunch of the fuel components such as, the fuel pump, filter, fuel pressure regulator. the pump is working fine. im reading 42 lbs of pressure and i checked the flow which was fine as well. the car only runs on ether. could it be i need new injectors or to be cleaned? or is it something with the computer?
thanks
Old Aug 29, 2010 | 04:14 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 91 z28 injection
can you tell if its running rich or not? Does fuel pressure stay constant after priming the rails? That can determine if the injectors are leaking, or if the regulator is bad, or if the pump has a bad check valve. Since you replaced those last 2 items, then probably look at injectors.
If you could get the car working and heated up, do an ohm test on the injectors. Ohmeter to the metal prongs on the injectors and see what they read. Should read near 15-16 ohms i think when warm.
Do you have good ignition/spark at the plugs?
Old Aug 29, 2010 | 05:51 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
If you engine will only start on starting fluid/ether then your fuel injectors are not pulsing, no fuel is getting into the cylinder. most likley cause is a failed ignition module
or maybe a bad pick-up coil.
Old Aug 29, 2010 | 06:13 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
^^^^^^ or the Vats system
Old Aug 29, 2010 | 07:45 PM
RoadHammer's Avatar
Car: 1991 Camaro Z28
Axle/Gears: stock
What John 89 formula said.
I just went through the same problem.
Old Aug 30, 2010 | 04:44 PM
yes i do have ignition to the spark plugs because it did run strictly on ether.
Old Aug 30, 2010 | 09:32 PM
Spark yes, but no fuel. Take the ignition module to autozone and have it tested, and go from there. The ignition module also tells the fuel injectors when to fire.
Old Aug 30, 2010 | 09:41 PM
i appreciate it. ill post the results in either a new thread or in this same one
racereese
Oct 10, 2015 09:39 PM
customblackbird
Oct 1, 2015 04:30 PM
sleprock
Oct 1, 2015 09:39 AM
mackjar66
Sep 14, 2015 01:17 PM
m00n420
Sep 11, 2015 02:39 PM
