stumped, please help!!
Old Sep 1, 2010 | 08:37 PM
Guest
Guest
Posts: n/a
hi, i noticed that one of the screws that hold my tps in place was snapped off. so i went to remove the other one and yep, snapped that one also!!!!! i just bought a new bbk throttle body,(after working on my old one for a few days with no luck) and i cant seem to find the correct size screws for that tps????? i took the t.b. in to the parts store and a harware and not one screw would fit!!!! anyone ever have this same deal? thanx in advance!! or know what size screw is correct?
Old Sep 1, 2010 | 11:00 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: stumped, please help!!
you can get them on ebay. FWIW, if you buy a new TPS, which you might need someday anyway, they come with new bolts. Try Advance Autoparts
Old Sep 2, 2010 | 08:54 PM
Guest
Guest
Posts: n/a
Hey thanx for the info, but I ended up tapping the holes to a 10/32 hole. Hope this will help others in the same situation as the new tps don't come with the new screws. At least that's what all the parts stores around here told me, even the gm dealership said the same thing??
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
djmarch
May 8, 2016 11:32 AM
Quzyle
Oct 15, 2015 03:35 PM
tuningnewb
Sep 23, 2015 07:06 PM
camarohelp
Sep 22, 2015 03:19 PM
