Dual Intake/Plenum?
Old Sep 4, 2010 | 02:50 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Dual Intake/Plenum?
anyone ever done it?
Old Sep 4, 2010 | 03:41 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Dual Intake/Plenum?
Done what, exactly? That's a carb in the picture.
Old Sep 4, 2010 | 04:00 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
sorry..shoulda been more specific...has anyone done a dual intake setup like that on a TPI?
Old Sep 4, 2010 | 04:06 PM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
do you mean dual cai? SLP use to make one but there rare and expensive now. At first i thought you ment two tpi intakes with 4 runners on each intake all on one engine, now that would be awesome
Old Sep 4, 2010 | 06:05 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
lol..yeah that would but yeah i mean a dual CAI setup..ive seen the k&n one but i wanna see custom made ones i guess....
Old Sep 9, 2010 | 05:52 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
anyyyyyyonnnnnneeee?????????
Old Sep 9, 2010 | 07:22 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Wouldn't that require two MAF sensors tho? I'm sure that would be one HELL of a job reprogramming the ECU lol.. Better getting one bigger tube behind the headlight OR keeping the stock one (which is fine for TPI no?)
Old Sep 9, 2010 | 11:30 PM
Drac0nic's Avatar
If it's SD it should be doable without too much issue. I'd take a piece of 3" and make a merge. It will be roughly 4". I would guess it would be a custom piece. That being said it's the price you pay for being cool and different.
I've thought a cool design would be to do a set of TPI runners up where they were cut off at a 90 degree angle roughly like a Lingerfelter intake (instead of doing a 180 like stock) and then doing 2 plenums/TBs instead. Doubt it would be any more functional just look neat. Throw a set of stock Vortec/LS1/whatever TBs on there and call it a day.
Old Sep 11, 2010 | 02:10 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
ehh...ls1 swap = i want
ive heard this can be a BIG power increase tho...i HEARD 30+hp
Old Feb 9, 2011 | 02:59 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
forgot about this thread..anyone have any?
Old Feb 9, 2011 | 03:25 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Well some of the camaros have a dual snorkel CAI factory that draws from in front of the radiator, the airbox is basically y shaped, so it only needs one MAF, its the setup my car has on it, unfortunately, I do not think they work with the firebirds because of hood clearance or something, but you could probably adapt one to work somehow.
Old Feb 9, 2011 | 03:31 PM
Twin_Turbo's Avatar
irocdennis used that on a carb, something like that on a tpi would be like the slp cold air induction
Old Feb 9, 2011 | 08:15 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
havent seen anyone do a true dual plenum/tb setup but i'd love to try it. Just not sure how you'd do that electronically and mechanically on the linkage.
I dont see the advantage in dual CAI... just run one big tube to the side. Packaging is only reason i can see a dual intake setup...two smaller pipes are easier to route in the engine bay
Old Feb 9, 2011 | 09:47 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
well, i was thinking like how the SLP CAI is but with the MAF like how its positioned on the camaros Y Box..
Old Feb 10, 2011 | 10:39 PM
90tararebird's Avatar
Car: 1990 trans am
Engine: 350 tpi
here ya go.
Old Feb 10, 2011 | 10:43 PM
Engine: 3.8, 3.4
Looks like that setup requires relocation of the battery and deletion of the charcoal canister.
Old Feb 10, 2011 | 10:45 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
And a change in the upper rad hose.
Old Feb 10, 2011 | 11:43 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Originally Posted by 90tararebird
I want! Would it be possible to take multiple stock intakes and fabricate something like that?
Also, could you get a photo of the underside of the driver's side so we can see the routing on the upper radiator hose?
Old Feb 15, 2011 | 01:35 PM
fyrebird68's Avatar
I've seen it done on Fieros more than once:
Attached Thumbnails Dual Intake/Plenum?-ed_parks_swapmeet_013.jpg
Old Feb 15, 2011 | 01:48 PM
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
i think dynodon would be able to make one....
spoke to him a whileeeeeeeeeeeeeeeeeeee back about something like this
91 SrS
Oct 7, 2015 04:32 PM
zman1969
Oct 1, 2015 11:09 AM
