Will this cam make a difference?
Old Sep 6, 2010 | 01:55 PM
SovereignDragon's Avatar
Car: 1990 Trans Am
Engine: 305 TPI (for now)
Transmission: 700-R4 (for now)
Axle/Gears: 2.73 10 bolt (for now)
Alright, so I've been gutting my 305 TPI to swap in a cam from a 94 lt1 b body that I had laying around. Hoping for more power, but here's the thing. When I got my cam out I realized that I had a 773 cam, that's right the L98 cam. So will putting in the cam from a 94 b body actually help? I can't find all the necessary info for the cam to add it to my desktop dyno. I need help fast please.
Old Sep 6, 2010 | 03:07 PM
Car: 1990 Trans Am
Re: Will this cam make a difference?
Come on, someone has to know something. I need to get my car back together soon.
Old Sep 6, 2010 | 06:21 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Nope, the B-body Cam is smaller than what you already have.
L31 or B-body LT1 camshaft 10243779 191/196 - .418/.430 111 LSA
You'd be better off getting some 1.6 rockers than installing that cam.
Old Sep 6, 2010 | 07:21 PM
Car: 1990 Trans Am
Yeah I agree with that completely, but the problem is the L98 cam is already pulled out and I've got the two sitting side by side. I was only doing this because I had the cam laying around. I have an LT1 that I'm going to build up so I don't really want to put any money in my little 305. If I'm reading the numbers right then the B Body cam would drop the powerband a little but not really give much more power. Is this true?
Old Sep 6, 2010 | 07:34 PM
Very true. If you don't want to spend alot of money just pull the LT1 cam out of your LT1 for now and use it. What year is your LT1?
Old Sep 6, 2010 | 07:46 PM
Car: 1990 Trans Am
It's a 94 from a roadmaster. I got it from a guy at work for 200. It spun the number 4 rod bearing and ate up the crank. Eagle rotating kit, lt4 hot cam, nice heads and a twin 54mm throttle body should make some decent power. I'm thinking lt4 heads to go with it.
Frozer!!!
Jan 19, 2024 04:55 PM
Out-Cast
Mar 22, 2019 09:39 PM
onefreakz
May 14, 2018 12:15 PM
Fronzizzle
Aug 9, 2015 01:15 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
