Not sure that my car is suppose to do this..
Old Sep 21, 2010 | 12:38 PM
PontiacMC's Avatar
Car: Trans Ams
My 88 GTA with LB9 in it with 118k and bad valve seals gets a really good 2 gear burn. Not just a churp but enough to leave marks and kick out.. Oh and its auto. All I can see that it has is straight 2 1/4 exhaust, cone filter, and MSD distributor cap. Now thats just looking at it, I havent had the car long so I havent really dug into it. I have known a few people that had he similar car and the only ones that could do this were the 5 speeds, and even them just churped alittle. Any hints on what I should look at or is his normal for the 305 TPI?
Old Sep 21, 2010 | 12:51 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: Not sure that my car is suppose to do this..
shift kit in the tranny, maybe. Even then thats not enough for it to break free like that
mine would do that (but only on good days),but it had an l98 with headers and 3" exhaust and 3:42 gears and a shift kit
I miss that car.
Old Sep 21, 2010 | 01:00 PM
PontiacMC's Avatar
Car: Trans Ams
ya maybe it shift awsome. I got the car and the trans mount was broken but even then it would kick out. I put a Energy trans mount on and now it does it everytime.
Old Sep 21, 2010 | 03:21 PM
PontiacMC's Avatar
Car: Trans Ams
oh one thing I forget to add. This car moves very well all the way through the rpms, has no problem getting to 5k.
Old Sep 21, 2010 | 05:51 PM
Drew's Avatar
-deleted
Old Sep 21, 2010 | 07:15 PM
PontiacMC's Avatar
Car: Trans Ams
do you know the code for the ratios? My tires are pretty good, 245/55/16s and they are Goodyears but not sure what kind.
Old Sep 21, 2010 | 09:43 PM
Drew's Avatar
-deleted
Old Sep 21, 2010 | 11:32 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Back in '86 i had a 305TPI with a shift kit, that would smoke the tires in 1st and 2cnd, I'm not sure the gear ratio i had. I also had Goodyear Eagles, I think the rubber compound was a little harder than other tires which helped on the burn. Back then they were $265 a tire, which was a lot, so there wasn't much burning going on.
Old Sep 22, 2010 | 09:27 AM
PontiacMC's Avatar
Car: Trans Ams
I couldnt find the codes list, but there was 2 tags on the differ cover. One said Spin Resistant Diff USA Approved and the other had a the gear size....3.27. It looks like I need to change the fluid on it, doesnt look like it was even touched.
Does it make a difference that it is a WS-6, or is that just suspension in these years.
Old Sep 22, 2010 | 02:42 PM
Drew's Avatar
-deleted
Old Sep 22, 2010 | 03:35 PM
PontiacMC's Avatar
Car: Trans Ams
ya I know what you mean. I have a 99 WS-6 also and its just the hood and airfilter that makes it a WS-6.
sonu1975
Aug 11, 2015 08:38 AM
novaderrik
Aug 10, 2015 12:44 PM
BrianI
Aug 9, 2015 11:52 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
MENINBLK
Aug 5, 2015 11:58 PM
