86 IROC won't run right unless I unplugged the timing connector
Old Sep 23, 2010 | 09:46 AM
raycer's Avatar
Car: 86 IROC
Hi, everyone, I'm having this problem with my IROC. When I start it, it barely has idle and if I give it gas, it just tries to cut out, like power is clicking on/off. Now if I unplug the timing wire, it runs fine. It has a great idle and every thing.
Stuff that has been replace recently are the ign module, plugs, wires, coil,
and after problem started
oil press switch, fuel pump and relay.
timing is set at factory spec.
Is it a bad ecm perhaps?
Old Sep 23, 2010 | 11:32 AM
raycer's Avatar
Car: 86 IROC
Re: 86 IROC won't run right unless I unplugged the timing connector
Also, if I unplug the MAF, the car won't stay on at all; but ff I unplug the IAC or egr solenoid, there is no change; only removing the timing connector has a positive effect.
Old Sep 23, 2010 | 01:35 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
any codes?
I'm thinking bad esc module...
Old Sep 24, 2010 | 11:28 AM
raycer's Avatar
Car: 86 IROC
no codes and the check engine light behaves normal. I just replaced the pick up coil to no avail, but I did notice something odd. If I unplug the connector from the alternator, the car idles perfectly and then dies 10 seconds later.
Old Sep 24, 2010 | 07:07 PM
raycer's Avatar
Car: 86 IROC
ok, new esc, same problem.
someone mentioned a bad ground so I will check that.
Also my cts' plastic is broken but the connector/pins still are attached. I was going to change it but the cts is seized in there and I haven't been able to remove it.
Old Sep 24, 2010 | 07:20 PM
thewizard's Avatar
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
I'm not sure if these cars are set up like this but.......you mentioned the oil pressure switch.......does the ECU have to see oil pressure in order to give the ignition and/or injectors the "go" signal? Possibly a weak connection or bad sensor?
Old Sep 24, 2010 | 07:29 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Have you put a timing light on it? Check it with the connector plugged and unplugged.
Old Sep 24, 2010 | 09:05 PM
Pull the alternator and have it tested, there could be a short in it, a bad alt will cause all kinds of problems.
Old Sep 25, 2010 | 06:20 PM
raycer's Avatar
Car: 86 IROC
problem solved. $5 ground strap
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
mustangman65_79
Aug 11, 2015 03:17 PM
