dunno what this is...
Old Sep 23, 2010 | 08:59 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Too dark to take a picture, if nobody knows by tomorrow I'll throw one up...
What is the name and function of a little module that sits on a bracket underneath the ignition coil, has two wires running out of it, and two vacuum lines going in from somewhere under the plenum? I mounted mine upside-down for clearance so I could loosen the distributor hold-down nut and set timing. It looked to be in pretty rough shape and probably is a vacuum leak, I'm curious to know if it is something I can safely get rid of or should be replacing instead.
Old Sep 23, 2010 | 09:08 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
Re: dunno what this is...
egr solenoid is my guess, if you have tailpipe emissions laws in your state, you will need it
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
sounds like the egr solenoid
Old Sep 24, 2010 | 07:56 PM
el_muerte's Avatar
Car: '87 Z-28
Thanks, no emissions here (Alberta) but I'll leave it in until I know it's a problem.
Old Sep 24, 2010 | 08:08 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello el_muerte!!
If you remove it, be prepared to have your "SES" light stay on, as it will trigger a code 32!!!
grngryoutmyway
Oct 18, 2016 05:48 PM
Stryker412
Sep 7, 2015 09:11 AM
One Eyed Jack
Car Audio
16
Aug 24, 2001 01:00 AM
KlayBuRn
Car Audio
May 15, 2001 02:20 PM
eatmydust
Apr 13, 2001 01:26 PM
