Injectors won't fire
Old Sep 27, 2010 | 07:56 AM
SBAUERZ28's Avatar
Car: 89 GTA, 80 Chevette
Engine: 350 TPI, 358 Carb
Transmission: 700R4, TH350
Axle/Gears: 9 Bolt, 8.8 with 3.73
Here is my problem. 89 Trans Am GTA with 350 TPI. This is weird but most of the time this thing will not start. Just cranks and cranks. Sometimes it will fire right up. When you turn the key on you can hear the fuel pump run and its always got good spark. The injectors are new Bosch III's, but when it dont start you can crank it and hold onto the injectors and tell there not pulsing. Doesn't seem to be related to temperature. I dont know if it's related but I already put 2 VATS relays in it. The one in the drivers kick panel. It seems to eat them quickly. But before if I jumped the 2 big wires in the plug it would start right up. So what would allow this to have good start but not fire the injectors and when it's running it will run all day long with no trouble?
Old Sep 27, 2010 | 06:19 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Injectors won't fire
VATS has two parts;
it takes out the starter and the injectors. Bypassing the starter enable relay only gets you the starter working.
Unless the computer sees the input signal from the VATS module it will not pulse the injectors so will crank all day
As it is a intermittent fault ,maybe bad connection from VATS module to ECM , maybe flaky VATS module
Old Sep 28, 2010 | 02:32 PM
InjectorsPlus's Avatar
Former Sponsor
Originally Posted by vetteoz
VATS has two parts;
Hey VO, always there with the great information. It's appreciated by everyone.
Old Sep 28, 2010 | 07:37 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
injector fuse?
Old Sep 29, 2010 | 01:45 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I get around
Old Sep 29, 2010 | 04:45 AM
SBAUERZ28's Avatar
Thanks to vetteoz for that wiring info. I didn't know the VATS also controlled the injectors. I measured my key at 6000 ohms, cut the wires under the dash and wired a resistor inline. So far its been starting all the time like it should. Thanks for the help.
Old Sep 29, 2010 | 07:20 AM
Former Sponsor
Great resolution, thanks for posting the result.
Old Sep 29, 2010 | 07:47 AM
Former Sponsor
I get around
When do you sleep?
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 21, 2015 07:20 PM
justin57
Aug 20, 2015 07:05 PM
