Fuel pressure dropping
Old Oct 8, 2010 | 01:24 PM
trona's Avatar
When I turn the key on but do not crank the motor the fuel pressure gos up to 45 lbs the when the pump stops in about 3 seconds it drops back down to nothing is this normal.
I smell gas on startup and was wandering if I had a leaky injector.
thanks Dave
Old Oct 8, 2010 | 03:04 PM
Rod Behring's Avatar
Car: 88 IROC
Engine: L98 HCI
Axle/Gears: 3.27 9 bolt
Re: Fuel pressure dropping
The pressure should not drop like that. You probably have a bad check valve in the fuel pump.
Old Oct 8, 2010 | 03:34 PM
trona's Avatar
I think i figured it out. When I clamp of the return line the pressure remians high. So I ordered a new pressure regulator today.
Hopefully this will also address a problem I have been having with inconsistent BLMs.
dave
Old Oct 8, 2010 | 03:47 PM
InjectorsPlus's Avatar
Former Sponsor
Could be an injector too. If the regulator doesn't do it, send us the injectors, we'll check them. If you're sure it is the injectors, let me know how I can help you out.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
