22lb Bosch 3's vs 24lb Bosch 2's (ford blue tops)
Old Oct 8, 2010 | 04:41 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
I have a stock engine, stock TPI 350 car. I currently have the 24lb ford blue tops, they are basically brand new have like 2500 miles on them. I have a set of 22lb Bosch type 3's that prolly have around 10k miles on them. Should I even bother swapping them out? The car runs phenomenal (now that I have fixed the misfire)
I know the 3's have a superior spray pattern, but is there really any performance to gain to be seen?
Old Oct 8, 2010 | 04:53 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
Re: 22lb Bosch 3's vs 24lb Bosch 2's (ford blue tops)
Congrats on your car running phenominal. Not many people can say that about their third gen, so why would you wanna change anything? Especially replace a part with a used part and that has more miles on it?
Old Oct 8, 2010 | 06:05 PM
Thank you, I am pretty picky about my cars I spend any necessary time keeping them running well. The injectors came out of a close friends car and are only 2yrs old at the most. The only reason I would change anything is the never ending goal to make more power and go faster.
Old Oct 8, 2010 | 09:28 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
oh yah man I definetly understand, I went from trouble shooting my 305 tpi to droping almost 4k in my new 350 engine. and junking the lb9.
Old Oct 8, 2010 | 09:29 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
im sure you know about the different spray patterns but here is a link
of both of them
http://www.youtube.com/watch?v=VfynoxL2RZI
Old Oct 8, 2010 | 10:01 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
I really didn't know the difference in spray pattern was that great. I can now see why everyone raves about them.
Old Oct 8, 2010 | 10:16 PM
InjectorsPlus's Avatar
Former Sponsor
Keep the 22s in there until you do some ugrades that require the 24s.
What's more important is that your Bosch IIIs are probably flow matched. The 24s aren't. That's as, if not more, important than anything else.
Old Oct 9, 2010 | 12:36 PM
Aparently you didn't read my post correctly. I have the 24lb SVO Bosch 2's in the car currently. The blue tops are flow matched, they came from AZ TPI.
I have the 22lb Bosch 3's on my work bench. They are also flow matched.
I am just wanting to know if there is a performance increase. (which I doubt there will be)
Old Oct 9, 2010 | 12:43 PM
I definitely have to agree! They definitely mist the fuel 1000% better! The smaller the fuel particle the easier it is for atomization to take place. I have read the bosch 3's will help smooth out idle and acceleration too. Just wondering if that is from going to an older not matched set.
I am basicaly trying to pick the TGO brain trust to find out how much of an improvement, if any, will be seen in any aspect of how the car runs.
Old Oct 9, 2010 | 12:46 PM
Jeffs82TA's Avatar
Just a question, to get the 24lbs per hour did you back your fuel pressure down on your tpi or are you still at 43.5 psi? I would like to get these for my vette but according to everything I have read they are rated at 24lbs per hour with fuel pressure at 36psi.
Old Oct 9, 2010 | 01:28 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
it depends on who you get them from, Southbay rates his modified bosch III at 24lb at 43 psi.
Old Oct 11, 2010 | 10:54 AM
The ford blue tops are rated at 24lb/hr at 39.5 psi. Typically the Bosch 3's are rated at 43.5 psi. I have a walbro and and Adj fuel pressure regulator, so that has no bearing on it.
Old Oct 11, 2010 | 11:21 AM
Former Sponsor
No , didn't. Don't swap them they aren't worth it.
Sell the Bosch IIIs. Having them sit around can make them sticky and fail.
Old Oct 11, 2010 | 05:21 PM
Your post said to keep the 22lb's in there. Which aren't installed in the engine currently. Therefore you either read my post wrong or you didn't type what you had intended.
Thank you for your advice about not swapping them.
Old Oct 11, 2010 | 08:46 PM
86 toy's Avatar
Car: 92 Z-28
Engine: Tuned Port 305
Transmission: 5speed
i say swap them out , run it and let us know how they work compaired to the SVO's
Old Oct 11, 2010 | 09:13 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
i dont know i would leave it alone his car is running great, changing your injectors is not an easy job you have to take off a few parts to get to them and that leave room for error or messing up parts gaskets etc. I would sell them and make some money on them.
New2Chevy
Oct 4, 2015 11:27 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
Firechicken86
Aug 12, 2015 10:07 PM
mustangman65_79
Aug 8, 2015 01:18 AM
