Won't Start
Old Oct 14, 2010 | 05:37 PM
protestthehero's Avatar
Won't Start
Hey guys
Im having a problem with my 91 z28 305. ive replaced nearly everything fuel related. fuel pump. fuel relay. fuel filter. fuel regulator. fuel injectors. etc. whenever i try to start the car all it does is crank over. if i give it a shot of ether it will run and stay running. im lost
thanks
Old Oct 15, 2010 | 10:59 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: Won't Start
Any trouble codes? Is the SES light on? Sorry that you spent all that money. Maby there is not enough spark? Any colorful exaust? Does it happen when cold or hot? Any smell of fuel? Pull out your spark plugs and check the gap. It should be .035. Try this. While cranking the Camaro, Slowly press on the gas pedal until it bottoms out. If it doesnt start, then check the timing. Timing chain may be stretched out. The plug wires may be bad. The distributor may be going bad (ESC Module, pick-up coil or even the coil. Since you done everything possible with the fuel system, move on to the ignition system. Look at it this way, your fuel system is now up to date. Let me know what your results.
Old Oct 17, 2010 | 07:26 PM
Re: Won't Start
lets see. i replaced the spark plugs, they're gaped correctly. i replaced the ignition control module and spark plug wires. the timing is 6 degrees advanced. uh it was weird. one day when i got home from work, i went to start the motor just to see what it does and it started. have no clue why nor am i complaining. thanks tho
Old Oct 17, 2010 | 07:43 PM
Re: Won't Start
That's strange. At least she's good to go.
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
EFR2000
Aug 18, 2015 08:54 PM
