1989 350 tpi upgrade help
Old Nov 6, 2010 | 09:51 PM
ResQ89's Avatar
I swapped a 1989 gta l98 into my 1989 camaro and have edelbrock headers and a 3 inch flowmaster exhaust along with a 2.73 posi. I took it to the track today and i ran 14.3s all day. Over the winter i would like to do some more mods to it. I would like to do a cam swap and some nitrous and also would i need a chip burnt for these mods. I would like to know any suggestions for a combo. Heads are still a possibility too. Thanks for any suggestions. Budget is at 1500 as of now due to being a college student.
Old Nov 6, 2010 | 11:05 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
Re: 1989 350 tpi upgrade help
I would check out craigslist and other sources for used parts since you are on a tight budget.
Check out this thread for NOS. I know NOS makes a bolt on fogger kit for 150 HP shot that I believe was around $600.
https://www.thirdgen.org/forums/powe...s-kit-tpi.html
Link to kits
http://www.jegs.com/i/Barry-Grant/13...oductId=754113
http://www.compucarnitrous.com/index...kits&Itemid=66
You might be able to find a thirdgen or fourthgen rear end with better gears to swap in. 3.23 or higher would be better. There are cams that are slightly more aggressive than stock that won't require a tune. I don't think any money in heads is worth it. Get some NOS with better gearing and enjoy the fun while on a college budget.
Old Nov 7, 2010 | 10:08 AM
ResQ89's Avatar
I was thinking about running the crane cams 2032 but would that be a descent cam to run wit nitrous, and other than springs and lifters would I have to change anything other than burning a chip for it. Thanks Blackdog for some suggestions.
Old Nov 7, 2010 | 11:35 AM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Originally Posted by ResQ89
along with a 2.73 posi. .
swap that first, 3:42 or 3:73 would be great, 3:42 would be a great all around gear. might as well get a disc rear, check the boards usually anywhere from 250-400
Old Nov 7, 2010 | 07:42 PM
ResQ89's Avatar
3.73 does sound alot better then the 2.73. Are there any better cam selections that would give me more power then the crane 2032?
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
