305 to 350 , what shortblock to get ??
Old Nov 9, 2010 | 11:07 AM
ray jr's Avatar
instead of building the 305 im thinking of just putting a 350 in.. what 350 shortblock should i look for ? 87-96 ? i just want the short block because i would like to put on aftermarket heads and aftermarket tpi intake parts.. so basically i would just like to change cams and add heads and tpi intake ...thanks for any advice .
Old Nov 9, 2010 | 11:41 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305 to 350 , what shortblock to get ??
87+ if you want to run a factory roller cam setup. Otherwise a block with whichever RMS type you already have will make it closest to a direct swap. Condition of the block is probably more important than anything else.
Old Nov 9, 2010 | 11:57 AM
ray jr's Avatar
so from 87 to 97 the block , crank,rods and pistons were all the same ?? none of the years had better pieces , strength wise ?
Old Nov 9, 2010 | 12:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Cranks and rods are about the same regardless of application. Pistons varied in design, but not in strength.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
