I want to run 11's on motor, what else do I need to do?
Old Nov 18, 2010 | 09:31 AM
  #51
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
Re: I want to run 11's on motor, what else do I need to do?
I havent heard of dynamics...as long as it gives you the ability to adjust all the basic parameters in the bin file it should be good to go.
http://www.dynamicefi.com/
Got a link to what you use? I would like to look at it.
Old Nov 18, 2010 | 11:56 AM
  #52
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I see thats EBL. That should work but you can just use your stock ECM and get tunepro rt to tune it.
www.moates.net he has all the stuff you need.
Old Nov 18, 2010 | 02:22 PM
  #53
Axle/Gears: G92
I'll have to look into that, doesn't it basically do the same thing and flash the stock ECM?
Old Nov 18, 2010 | 02:27 PM
  #54
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
You have a chip adapter and burn chips and plug them in. Its not really a reflash of the ecm like LS1 stuff.
EBL is common with TBI but i am not familar with it, nor do i know how well it works with TPI based stuff. I'm sure it can cover it tho.
Old Nov 18, 2010 | 02:58 PM
  #55
Axle/Gears: G92
So the ebl is a reflash and tunerpro is a chip burning thing?
Old Nov 18, 2010 | 03:30 PM
  #56
Axle/Gears: G92
Can someone post a link or part number for the vortec Holley stealth ram because I'll can find is the 4k kit with the command 950 ecu
Old Nov 18, 2010 | 07:46 PM
  #57
Axle/Gears: G92
A few other questions, will the HSR fit under a stock 92 z28 hood?
Old Nov 18, 2010 | 09:18 PM
  #58
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
May need minor bracing trimming. I had to cut a touch out with my stock hood.
Old Nov 18, 2010 | 09:45 PM
  #59
Axle/Gears: G92
Acutal cutting up the brace or just minor trimming? Like you wouldn't notice? Alittle grinding?
Old Nov 18, 2010 | 11:41 PM
  #60
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
If your going though all that stuff, Upgrade the stock ecm to the 411 OBD2 so you can flash like the LS1 I had my 383 running on the 411 OBD2 ecm and it was night and day differance. Drivability was like a new car. For the record I had a 383 10:3:1 old school TF 190's and the Outdated LPE219 cam. I was running mid 12's with a 2600 Edge converter. 360 something RWHP and 380ish TQ
Old Nov 19, 2010 | 08:25 AM
  #61
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
actual cutting out some spots of the bracing. if done right, you wont really notice it missing. I never had people come up to the car and look at the underside of the hood.
Old Nov 19, 2010 | 08:35 AM
  #62
Axle/Gears: G92
I'll look into it, thanks
That sucks it doesn't fit good under the hood without this.
Old Nov 22, 2010 | 10:56 AM
  #63
Axle/Gears: G92
Will mini ram fit with no cutting? Will it work with vortec heads?
Old Nov 22, 2010 | 12:08 PM
  #64
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
They do make a miniram for vortec heads i do believe. It is a short intake and easily clears the hood.
If you have new poly bushings for motor mounts, HSR will rub on the hood where it meets the TB. It did on my Irocz. Before the poly mounts on stock bushings, it only hit on one spot so I cut that small 3"x3" square piece out. I dont know why everyone is so upset at cutting the underhood bracing, theres not much to cut and you dont really notice it. It doesnt hurt the structure of a steel hood.
Old Nov 24, 2010 | 09:58 AM
  #65
Axle/Gears: G92
It doesn't bother me cutting it, I just don't like the idea of cutting my orig hood. I've found pics And it's not a big cut.
Old Dec 3, 2010 | 12:31 AM
  #66
Axle/Gears: G92
What about the ramjet? How you feel about that setup?
Old Dec 8, 2010 | 05:35 PM
  #67
Axle/Gears: G92
What's the part number for the vortec stealth ram without all the computer stuff. Just the stuff I need.
I do need the fuel rail correct? What fuel pressure regulator should I get?
Old Dec 8, 2010 | 06:14 PM
  #68
Axle/Gears: G92
http://www.summitracing.com/parts/WND-7542/
Ok I think I found it. What fail rail kit should I buy? Also what regulator?
Old Dec 8, 2010 | 07:51 PM
  #69
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Ramjet is an ok intake as well. Smaller plenum tho, some say that makes alittle difference in throttle response but with good AE tuning it shouldnt matter.
Proflo XT is also available in vortec i believe. Not a bad intake either. All about the same with HSR intakes.
7542 is right vortec stealth ram. NEed the vortec stealth ram fuel rail kit too. Regulator you can try holley's but they have been known to fail. Mine never did for 2 years but others have. you can upgrade to the Kirban fuel pressure regulator for 85-87 grand national cars. Its billet and about 120 bucks or so. Fits the rails fine.
Old Dec 8, 2010 | 07:53 PM
  #70
Axle/Gears: G92
Do you have A link to the vortec fuel rail kit? Non adjustable regulator one is fine I'll later upgrade to that Kirban.
Never heard of that intake I'll look into it more.
Old Dec 8, 2010 | 09:41 PM
  #71
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
no but its on summit. Just have to look for it.
Old Dec 8, 2010 | 10:18 PM
  #72
Axle/Gears: G92
http://www.summitracing.com/search/?...il%20kit&dds=1
That is the only one coming up, says universal kit.. I can't find it
Old Dec 8, 2010 | 10:25 PM
  #73
Axle/Gears: G92
I found the part numbet on a few other sites and still can't find it at summit I'll be going to summit to get it and would like to find it. Can someone post a link or something?
Old Jan 20, 2020 | 11:31 AM
  #74
my hemi's Avatar
Car: A few things lol
Engine: 350 tpi supercharged and a 383 stro
Transmission: Both 700r4s
Axle/Gears: 3.23s and 3.54s
Did you ever build this motor?
eightsixseven
Dec 16, 2024 01:50 PM
jhawkeye
May 25, 2022 06:33 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Elliswon
Aug 10, 2015 12:33 PM
