LB9 to L98 - Correct Knock Sensor?
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
I'm going from a LB9 to a L98. The car is using a 1989 LB9 ECM. Which knock sensor should I use in the new L98? The LB9 had a 100k-ohm sensor and I've read the L98 needs a 3.9 k-ohm sensor. For what it is worth, the knock sensor that came out of the L98 is a 100 k-ohm as well, so go figure (I have no idea if the engine was running properly beforehand). Since my ECM is staying the same, should I stick with the 100 k-ohm knock sensor?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: LB9 to L98 - Correct Knock Sensor?
You need a 100k ohm ks, you might also check the part number on RockAuto to see if the esc is different.
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
The 1989 350 L98 knock sensor is #10456288.
The 1989 350 L98 ESC module: Alternate/OEM Part Number(s): 16052401, 16128261, 21647, ESC100
Cheers
Engine: 350 TPI L98
Transmission: WC T5
Thanks. I will try the 100K as that is what came off the 350 and what worked on my 305 with that ESC.
Engine: Lb9
Transmission: M20
I was under the Impression 305 and 350 esc modules were the same just the frequency of the ks was different.
see the above part numbers and get the correct esc module.
if you don’t you might chase false knock.
My friend was chasing this after changing to the 89 vette roller motor ks but still using his old 87 305 esc.
vasquezmrysvll
Apr 25, 2008 07:37 AM
