No Crank issue
Old Jan 2, 2011 | 02:24 PM
89trans_am_gta's Avatar
Car: 1989 trans am gta
Engine: 5.7 tpi
Transmission: automatic
No Crank issue
I have a 1989 GTA 5.7 tpi to fix up. Has not given me any problems starting at all until randomly when i went to start it there was 'no crank'. It happened right after we had a snow storm here. Its not a security issue, it was ripped out a while ago. I feel there could be an issue with connection to the starter. Does anybody have any input on what the problem could be?
Old Jan 2, 2011 | 08:18 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: No Crank issue
Battery good? ( old batteries and cold weather don't go well together ).It takes more power to crank in cold weather so if battery tied ..........
Battery cable connections good both ends?
Does starter work if you hotwire it ?
If it does then you have a problem with wiring from key to starter solenoid
Old Jan 9, 2011 | 03:41 PM
Engine: 5.7 tpi
Re: No Crank issue
the battery is pretty new. I just put on new battery terminals and still no crank. I havent tried to hotwire it yet. I assume its either a connection problem or a issue with starter or solenoid.
Cornholio7979
Sep 20, 2018 02:31 AM
WIzmo
Aug 30, 2015 02:30 PM
Jae992
Aug 27, 2015 09:07 AM
Bryan F
Aug 18, 2015 02:28 PM
mizz0313
Aug 12, 2015 06:45 AM
