two dead cylinders 88 350 TPI
Old Jan 3, 2011 | 08:06 PM
jt92's Avatar
Hi guys,
I have an 88 iroc that I swapped a 350 TPI into. Car will start and idle, but cylinder 5 & 6 are dead. Compression check is good on both. New plugs were installed during the swap. cap and rotor look good. Firing order is correct on the wires. injectors are getting 12 volts. I am looking for some advice on troubleshooting this problem.
Thanks.
Old Jan 3, 2011 | 08:08 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
Re: two dead cylinders 88 350 TPI
are the injectors spraying? just becuase they are getting power doesnt mean the head isnt all gunked up and just letting a drop of fuel in
Old Jan 3, 2011 | 08:20 PM
jt92's Avatar
What would be the best way to check that?
Old Jan 3, 2011 | 08:25 PM
Car: 1990 camaro RS
Engine: 305 TBI
i dont know if ur carful you could swap "5 or 6" with any of the other 6 that you know are working maybe some1 else knows a better way?
Old Jan 3, 2011 | 09:52 PM
Sighman's Avatar
Pull the wires on the plugs and crank it over then pull the plugs and see if they are wet.
Old Jan 3, 2011 | 09:53 PM
Car: 1990 camaro RS
Engine: 305 TBI
ahh yes thanks sighman i figured i was forgetting something easy to do.
Old Jan 5, 2011 | 08:12 PM
jt92's Avatar
I have some more info, see if this helps diagnose. Fuel pressure sits at 49 psi idle. I got it warmed up enough to go closed loop and store trouble codes. It stored a 34, map sensor signal low. I have a mass air car not speed density. Sorry, I see now that the code interchanges. Maf or map.
Old Jan 5, 2011 | 09:26 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I had the same problem once. It turned out that the two injectors weren't firing.
Old Jan 6, 2011 | 12:46 PM
jt92's Avatar
Ordered a set of injectors today.
Old Jan 13, 2011 | 07:05 PM
jt92's Avatar
You were right. New set of injectors from SouthBay and she is hitting on all eight.
Old Jan 14, 2011 | 11:32 AM
Artisan's Avatar
Car: 89 Iroc
Engine: 350/Dart heads/hotcam/TPI
Axle/Gears: 3.45 9bolt
Congratulations!
Old Jan 14, 2011 | 07:59 PM
jt92's Avatar
Ok, I hate to bug everyone. I had good results when I changed the injectors. So I decide to drive down the road and a mile or two down the road, right back to popping and stumbling. What can I check tomorrow? Fuel injectors are good. Compression is good. I do have a 305 esc on it even though it is a 350. 350 knock sensor. I just need some things to test to get me started.
Old Jan 14, 2011 | 08:06 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Bad ECM, maybe?
Old Jan 16, 2011 | 10:49 PM
jt92's Avatar
Ok, just to update. The problem was my fault. Some dummy...(me) didn't secure the plug wires before the drive down the road. Three wires were almost burnt in two by the exhaust. Thanks for the help getting the engine back to life.
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
