Small tube on the TPI runner?
Old Jan 4, 2011 | 07:12 PM
landofoz1978's Avatar
Car: 1991 Z-28
Can anyone tell me what the small tube on the runner is for? I took mine apart to change the injectors and that tube was almost completly clogged with deposits. I took it to the machine shop to get them and the plemun cleaned and when I went to pick it up he said that the hole that the small tube connects to on the plenum (which is a channel that runs under it and exits from two holes directly behind where the throttle body connects) was completly clogged. Just wanted to know what this was for, and what ill effects would be noticed from it being completly clogged??
Old Jan 4, 2011 | 07:13 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
Re: Small tube on the TPI runner?
pre 89 for egr and cold start injector i believe. If you have a 89 or up, its probably just for EGR
Old Jan 4, 2011 | 08:39 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Pass side runner tube is for EGR on all TPI
Drv side tube is CSI on early years
Old Jan 4, 2011 | 11:02 PM
Car: 1991 Z-28
OK then, I guess it is the EGR tube, wonder if it being clogged would make it throw the EGR code when cruising on the highway? It had been doing that for awhile only when on the highway, but would be out the next time I started it.
Old Jan 4, 2011 | 11:21 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Probably
Because if exh gas is not flowing through the tube, the EGR temp sensor would not heat up and operate.
The computer looks for the temp sensor operating when it turns the EGR on and if it doesn't see it; it throws a 32 code
Old Oct 15, 2011 | 07:50 PM
jb1's Avatar
jb1
what symptoms would occur if the gaskets were put on wrong side?
previous owner did this on mine and Im going to fix it tomorrow
Old Oct 16, 2011 | 01:13 PM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Gaskets on wrong side would probably result in vacuum leak ( High or rough idle, lean condition when running, backfiring, to name a few).
Old Oct 17, 2011 | 08:47 AM
jb1's Avatar
jb1
yup...previous owner had two right side gaskets as I suspected. Pics of the pass side runner EGR blocked some
Frozer!!!
Jan 19, 2024 04:55 PM
tazs2000
Jul 15, 2017 08:44 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
