Full bolt ons on stock 91 L98?
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Full bolt ons on stock 91 L98?
Those are totally different than an L98. Headers for those cars are mostly full length and the heads on those cars are way better than ours
Axle/Gears: 3:42
Yeah,but its not so much the intakes on those cars, its the heads,cam. What good is a bigger intake (a mouth) without the stomach(guts) to back it up
Axle/Gears: 3:42
You can only flow so much air in and then the heads and cam become the restriction. You see?Otherwise u have a mismatch of parts and the early guys that tried modifying TPI always went slower. We now know better nowadays.
Car: 1989 Trans Am GTA
Transmission: M28 T56
A full exhaust is the single greatest set of upgrades you can do to a TPI car. LT1 and LS1 cars make more power stock, so the percentage they gain from these mods is greater as well.
On average cars gain the most power from a full exhaust over other mods.
And an L98 will still gain more power from a full exhaust than from the intake side.
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
Ah I see. Sounds like I may get more gains from upgrading the intake when I do a head swap.
Aftermarket intake on an otherwise stock car might add 20hp. Not sure if it would be much fun on a stock car tho,unless you are at WOT .Larger throttle body will add nothing unless you have a need for it,like if u have better heads,cam,intake together. Ported plenum on a stock car might add 5hp
Runners + Base + time spent porting plenum vs a full exhaust. Full exhaust is cheaper too.
Good runners are expensive, almost the same cost as a base.
Car: 1988 IROC-Z
I've got 1 5/8'' ceramic hooker headers, 3''inch high flow cat, and 3'' flowmaster cat-back exhaust. The only intake mods I have done is open up the intake box, some k&n filters and a 52 mm throttle body. Everything else on the engine is stock.
I was wondering if it was worth it to upgrade the intake runners and base now or wait until later. I may do a head and cam swap at some point but not now. I am satisfied with the way the car performs now after the exhaust work.
Axle/Gears: 3:42
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Yes he is! If you look at my youtube page, All those cars on the Dyno has Dyno Don Headers except for my car. It has SLP's.
Well I tell y'all this, If somebody on this board will try the exact same setup as ItsMikey, lets us know how it turned out. The proof is in the pudding. The problem is that no one has ever tried this combo. That's why their are doubts. Everyone has tried the other ways and going with that.
I was at Dyno Don's shop 2 weeks ago and we put one of my SLP header next to his header and we notice that his header is about 2 inches longer that mine. Does that make a difference? Don't know.
Look at my SLP headers in the video and tell me what you think?
http://www.youtube.com/watch?v=JDX6r...1&feature=plcp
Axle/Gears: 3:42
you lean it out most of the time u mod your car, if you richen it back up sometimes u get even more power cause u are correcting the air/fuel mix
Completely unnessesary. Thats the hammer method of adjusting your AF ratios. Best to do it in the chip.
A higher pressure DOES make for a better spray pattern though in most situations. But for a stock car it won't help much unless you alter the Injector Constant in the chip to match the new flow rate.
L98 injectors have a flow rate of 22lb/hr @ 43psi. If you bump the pressure up to 48psi then the effective flow rate becomes 24.5lb/hr. So you'd have to alter the chip so the constant read 24.5lb/hr to maintain the current AF ratios. I had 24lb/hr injectors on my old build once before the chip was altered to match. Fuel economy was terrible to say the least. I drove it about 100 miles to a guy who could burn a chip for me and do some datalogging and on the way up there I got 12mpg. On the way back I got 20mpg. I never got a real tune on it though and it was never happy with the mostly stock tune. Had some bad surging issues at idle.
Good running STOCK l98's make 200-215rwhp. I have video proof too for what its worth. Yes, I do have the full video, no I don't have it in better quality.
http://home.comcast.net/~thirdgen89g...rottleDyno.m4v
Axle/Gears: 3:42
I see what you are saying, i am not talking stock, i am talking bolt-on car where the o2 signal is now reading leaner due to mods. Tuning is better of course,but an AFPR can be a band-aid. IIRC, raising the fuel pressure to 50 psi is like having 24lb injectors. Check out an article in chevyhighperformance magazine,where they added a set of dynomax headers and exhaust. Then they bumped up the fuel pressure and made more hp and torque. Yes, i do agree that fuel should be taken care of in the chip though. I just burned a custom SAUJP and mine runs much smoother and better performance all around.
Divide base flow rate @ FP rating, then multiply it by the new fuel pressure.
(INJ Flow / base pressure ) * new pressure = new flow rate.
Ford injectors, at least the SVO injectors are all rated at 38psi. So a 24#/hr SVO injector on a stock thirdgen will flow 27.1#/hr @ 43psi.
Stock 22lb/hr L98 injectors at 50psi flow 25.5#/hr.
Axle/Gears: 3:42
If u had 24lb injectors in your 350 TPI the correct injector constant setting is 24.02 lb at 43.5 psi of fuel pressure ,even Ford 24lb SVO injectors!
TPI/LT1 injectors are 43psi.
LS1 injectors are 58psi
SVO Ford injectors are 38psi.
Axle/Gears: 3:42
Incorrect. There is an actual formula for determining actual flow rate vs pressure.
No one can't dispute my last post. Wow!
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I've seem that video before. One of then had 2.77 gears and the other one had 3.27 gears. I think the one that made 207whp had 3.27 gears. Now with that in mind if that car made 207whp bone stock and some of you might say a full exhaust will be about 25hp gain, well add 207 + 25 = 232whp. Now how much more will a tune be? After that then add the possible hp of a gutted airbox with K&N filters. What will you get? Whoop there it is! Oh yea, This 88 L98 was rated at 230fwhp. 90-92 rated at 245fwhp and a 89 240fwhp.
But like many said, most L98 typically dyno 200-220whp stock, as it depends on the dyno as all vary to some degree. I think the 91-92's should have advantage as they supposively got the flat top pistons instead of dished. This should have more compression and make more power, 5-10hp more.
My car with stock TPI with headers/catback put down 204whp with the EST wire disconnected. I adjusted timing and forgot to put it back together!!! I ran 14.0 at 94mph like that when I normally was doing high 13's at 97 so 204whp was about 94mph traps, I'd say 97 was 230whp. Stealth ram bolted on, with no tuning I made 246whp, ran 99-100mph consistantly in abit warmer air so power was definately there. I'd say intake mods are worth just as much as exhaust mods. 15-20whp is possible with tune. Even tho the heads arent great and the cam is tiny, these cars still pick up good power with intake mods.
Car: 1988 IROC-Z
I've got a question about the dual cat exhaust. I've got headers and cat back. I've got an '88 so I only have the single cat. If I upgraded to dual cats how much of a gain in power would I see? Would it be worth the hassle?
Well a dual cat car 90-92 is rated at 245hp. A single cat car same years are rated 230hp. A dual cat car also was restricted with two 2 1/4in pipes and restricted Y-Pipe. We change that to 2 1/2in pipes and a Flowmaster Y-Pipe for a smoother merging flow.
Car: 1988 IROC-Z
Thanks for the info on the exhaust. I still think I'm going to work on the intake some more. I may come back to the exhaust later and put on the dual cats
Axle/Gears: 3:42
Dual cat cars are not really restricted, that N10 dual cat option was worth 13% more hp. It is equal to a single 3" ypipe
Axle/Gears: 3:42
Car: 1988 IROC-Z
Axle/Gears: 3:42
I said that cause for a better intake u may want better gears first. Cause u will be moving your powerband up higher and you will need to get up into the rpms quicker now, where that power is going to now be
Car: 1988 IROC-Z
Yeah I understand what you are saying. At some point in the future I will upgrade to 3.27 gears.
I guess no one can really dispute the possible HP.
Terrell351
Jun 13, 2021 01:13 PM
