VSS info this needs to be a sticky!!!!
Old Jan 17, 2011 | 10:00 AM
tranz am's Avatar
I just got done doing a TPI swap and i ran across an issue with my idle bouncing and engine stalling when i let off the throttle quickly.
My two TPI swapping books I have never covered the VSS in depth and what it was actually needed for.
Anyways, I was concerned with this VSS issue maybe causing a problem, so i did some searches here, on this site and came across a few discussions on the topic, some saying you need it, others saying you don't.
The most convincing of the two made it sound like I didn't need it since i would be running a T5.
Well sure enough I most certainly need a VSS fro the way my L98 is acting.
I Read up on it and finally found this article that i think explains the VSS quite well and why we need one, EVEN WITH A MANUAL TRANSMISSION!
Thought this might help some of the TPI swappers out there.
http://www.jagsthatrun.com/V8-chapte...ed-Sensors.pdf
Old Jan 18, 2011 | 10:16 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: VSS info this needs to be a sticky!!!!
https://www.thirdgen.org/forums/post...740-post4.html
Old Jan 19, 2011 | 01:23 AM
tranz am's Avatar
nice, lets keep the VSS knowledge coming!
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
