TBI to... TPI?
Old Jan 17, 2011 | 11:24 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
TBI to... TPI?
hey guys kind of just a thought but since you guys are the proud owners of TPI i figured i'd ask... and i havnt seen any threads about it but what would it take to convert from TBI to TPI? and if you're going to be the guy "oh just buy a f body with that set up to begin with" i dont want to see your posts on here. don't mean to be rude but im looking for informative answers here. thanks guys.
Old Jan 17, 2011 | 11:35 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
Re: TBI to... TPI?
prolly cuz if your gonna spend the time swaping why not do an lsx or ltx swap, its just as much work and much better performance then the TPI and it prolly will cost right about the same
Old Jan 17, 2011 | 11:59 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
Re: TBI to... TPI?
ok that was a fair enough answer. lol
Old Jan 18, 2011 | 12:09 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: TBI to... TPI?
from what i have researched it comes out pretty pricey but heres some info hope it helps you out
https://www.thirdgen.org/convert-tpi-fuel-injection
and if you have tbi read this one
https://www.thirdgen.org/tbitotpi
Old Jan 18, 2011 | 01:39 AM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: 700-R4
Re: TBI to... TPI?
LSx or LTx swap would cost much more than just a TBI to TPI swap.
Old Jan 18, 2011 | 04:01 AM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Re: TBI to... TPI?
Street and Performance sells a harness to do it for about $600 that is plug and play.
http://www.hotrodlane.cc
INTEGRATOR HARNESS TBI TO TPI
The Integrator Harness lets you go from Throttle Body to Tuned Port Injection on
your S/B Chevy 87 & up. Just plug it in. Uses #1227730, 88999196, 16198262
and 16196344 Computers. Complete $564.95. Automatic add $93.95 for vehicle
speed sensor multiplier.
All you have to do is unplug your throttle body computer and plug in our harness,
run injector wires to your TPI and change your existing fuel pump to an in tank high
pressure fuel pump, AC-EP241. This application is available for either S/B or B/B
Engines. Super Chevy did this in their 87 Blue Streak Camaro Project in 99.
Old Jan 18, 2011 | 07:42 AM
Car: 1990 camaro RS
Engine: 305 TBI
Re: TBI to... TPI?
Show me where you can find a tpi block with less the 50k miles on otherwise id rebuild it before I put it in my car. For the price of rebuild I could have the 5.3 ls outa the trucks. Intake to oil pan with injectors plugs wires coil pack water pump throtale body. I can get a harness and acceories outa a junk yard and then swap the fuel pump. Ok maybe a little more then a tpi swap but now my cars much more up to date. Imo doing a tbi to tpi swap is money poorly spent
Old Jan 18, 2011 | 07:43 AM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Re: TBI to... TPI?
As I understood the OP wants to change just the intake system. That does not really mean a full rebuild.
Old Jan 18, 2011 | 07:49 AM
Car: 1990 camaro RS
Engine: 305 TBI
Re: TBI to... TPI?
Old Jan 18, 2011 | 08:16 AM
Car: 1990 camaro RS
Engine: 305 TBI
Re: TBI to... TPI?
Ok so you swap the intake. You've still got the crap tbi heads and cam. Swap them without doing a rebuild is asking for ring failure if your motors got anything over prolly 100k on it. Y rebuild the 305 tbi to tpi specs when u could get a 350 tpi to rebuild then at that point it'd be what I say.
Old Jan 18, 2011 | 08:23 AM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Re: TBI to... TPI?
I really don't want to persuade you about doing a TBI to TPI swap or doing an LSx swap is better. If you have the money, time and knowledge, do your LSx swap. The OP asked about TBI to TPI swap so we should try and focus on this topic.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
