86 TPI & 90 TPI help
Old Jan 22, 2011 | 02:47 PM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
can u switch a 1986 305 TPI with a 1990 350 TPI......... just the whole TPI
Old Jan 22, 2011 | 05:35 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 86 TPI & 90 TPI help
Complete engine or just the intake?
Old Jan 22, 2011 | 08:04 PM
DiabloWS6's Avatar
just the tpi setup cause some guy said they were different and u cant put a 1986 tpi setup on a 350 centerbolt he said cause they had centerbolt valve heads and that had something to do with it
Old Jan 22, 2011 | 08:32 PM
Guest
Guest
Posts: n/a
Why would you want to do that?
You could put it on there, but there are a couple issues with doing that. The center 4 bolts will not line up right so you would need to elongate those holes, and the 90 intake does not have provisions for the cold start valve on your 86 so you would need to at least change to an 89 prom.
Old Jan 22, 2011 | 09:40 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Use the complete setup and get a chip for an 89 350 with the VATS turned off and you will be just fine. Keep it simple.
Old Jan 22, 2011 | 10:28 PM
DiabloWS6's Avatar
the reason im asking this is because i have a complete 1990 350 tpi and i have a complete 1986 305 tpi i took the tpi off the 1986 because some fake *** buster was gona buy it so now its just siting on the side of my car and a guy came to check out the 1990 350 tpi motor and only wanted the tpi but im selling that motor complete and i asked the question of changing tpi from those 2 motors so i can just sell him the one of the 1986 tpi and if it was compatible on a 1990 i know it has a cold start but u can block it off im not changing this to my car i preffer to sell the tpi i took off instead of taking the one of the 350 cause if he did nobody would want the 350 block with out the tpi
Old Jan 23, 2011 | 01:12 PM
Guest
Guest
Posts: n/a
Simple solution is put them on the year engine they belong on. If you dont, you're going to have to modify both bases to fit the heads. Other than that and the cold start they're pretty much identical.
Old Jan 24, 2011 | 12:50 PM
DiabloWS6's Avatar
yeah im not trying to keep them i was trying to see if i can sell the tpi off the 1990 350 and then swap my 1986 305 tpi on it but reading what u have posted there will need to be modifications to it....
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
