lt4 hot cam with stock intake?
Old Jan 26, 2011 | 03:06 PM
89lt1's Avatar
Car: 1989 firebird formula, 1991 z/28
Engine: none LSX! one day, 350tpi
Transmission: none t56 one day, t5
Axle/Gears: 9-bolt 3.45, 10 bolt 3.73
has any one done this? if you have do you have any results. I have a 350tpi. I am aware of the intake's restriction. Just curious. if it doesnt work that well i have an lt1 intake i may convert.
Old Jan 26, 2011 | 03:09 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: lt4 hot cam with stock intake?
It'll run and drive.
But you'll be missing out on a bunch of power that could be had with a matching intake.
You can run it with a TPI style system as long as its all hogged out and upgraded.
A LT4 hot-cam would probably run great with a FIRST LTR setup.
Old Jan 26, 2011 | 03:10 PM
89lt1's Avatar
How well would the lt1 intake work? and how high do you think it will pull w/ the stock intake
Old Jan 26, 2011 | 05:13 PM
Max power at 5000 to 5500 I'd guess. Not much use spinning beyond that. The heads will hold it back a lot.
My stock head/cam/intake LT1 makes max power around 5k with all boltons. It's a b-body lt1, smaller cam than F and Y cars.
Old Jan 26, 2011 | 08:40 PM
Artisan's Avatar
Car: 89 Iroc
Engine: 350/Dart heads/hotcam/TPI
Axle/Gears: 3.45 9bolt
I used the LT4 Hot cam in my build, with TPI. I have fully siamesed SLP Runners 2.5 inches in siamesed in my stock base with the base ported to a 1205 Gasket. My heads are ported Iron Eagles. Here is the thread on the build.
https://www.thirdgen.org/forums/tpi/...-my-305-a.html
I made 290/358 @ the wheels. The power under the curve is amazing. I absolutely love the combo.
Old Jan 26, 2011 | 09:06 PM
Yeah, but your combo is no-where near close to what he's proposing.
Your combo is well matched, you've upgraded everything. TPI's weakness is the poor flowing heads and poor flowing stock intake. Without upgrading both of those a cam swap will leave alot of potential on the table.
3.8 TransAm did car he called "Thor". Thor was making some serious power and trapping very nicely. It was a vortec headed, ported TPI setup with a LT4 hot-cam.
The original poster's proposal of just doing the hot-cam and on a stock intake will produce very little gain and cause a whole bunch of problems.
Old Jan 26, 2011 | 09:21 PM
Artisan's Avatar
Car: 89 Iroc
I agree with what you are saying. Anytime you change cams you must do the supporting mods or its a complete waste of time
MustangBeater20
Oct 29, 2022 09:20 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro71633
Sep 1, 2015 10:24 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
